help plz mk1 escort/sierra 16v rs2000 conversion
Old Aug 12, 2013 | 07:15 PM
danswift's Avatar
danswift
Default help plz mk1 escort/sierra 16v rs2000 conversion
hi all. im most the way through my build im using a sierra 4x4 floor pan and most the running gear but im only going rwd not 4 wheel and using a rs2000 16v engine and a type 9 gear box
the problem im having is when fitting the starter motor the engine wont turn over ie the starter just sniping and then when i put a ratchet on the crank pulley bolt the engine wont turn undo the starter and it turns freely
im using a dohc flywheel from the 4x4 sierra and the starter i tryed a pinto one today and still the same any help will be great thanks dan
Old Aug 12, 2013 | 07:54 PM
mk22door's Avatar
mk22door
Fart of the Purniture
I'm thinking you should use an 8v DOHC sierra sump, starter (not 4x4) and the MT75 RWD gearbox and it will work out a lot better
Old Aug 12, 2013 | 07:59 PM
mk22door's Avatar
mk22door
Probably not but I'm not sure if the 8v 4x4 flywheel is different to a RWD version - so check that out also.
Old Aug 12, 2013 | 08:07 PM
danswift's Avatar
danswift
hi thanks for the reply i read the flywheels are the same ? but ill take it off tomorrow just got to find another one. looking at it today it looks like the starter is hitting the starter ring on the flywheel so thinking its about 4/5 teeth to big
Old Aug 13, 2013 | 07:24 PM
danswift's Avatar
danswift
think iv sorted the problem iv got a starter off a rwd sierra and its now turning over its a bit slow but getting better.
now just trying to sort out the wiring
mk3ste
Oct 17, 2021 10:09 AM
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Sep 28, 2015 10:05 AM
Tank Mike
Sep 26, 2015 08:07 AM
