Central locking
Old Aug 9, 2013 | 06:46 PM
Ryoishikawa's Avatar
Ryoishikawa
Default Central locking
Rite guys and girls my locking keeps unlocking and locking its going mad .
Changed the fuse
Checked the wires
Cleaned the fuse
Cleaned the connections
Really need advise its a pain
James
Old Aug 9, 2013 | 07:19 PM
primedog's Avatar
primedog
have ur door card off and check the positioning of the motors, if they open all the way/close all the way and thers resistance they will close/open again..... take one off andactivate the locking and if it does it still then take the other off and see if still does it. if it works perfect wile ther off you just have to realign them when fitting them back up.
if thats not your problem im not sure what to suggest.
Old Aug 9, 2013 | 09:07 PM
neil73's Avatar
neil73
Take out the door locks and spray some freeing oil on them, mine was doing the same as yours and it was the locks that were sticking
Old Aug 9, 2013 | 09:53 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Also make sure the boot lock mechanism isn't seized mine did this and it was the boot mech seised up
Old Aug 9, 2013 | 10:44 PM
RS-Mitch's Avatar
RS-Mitch
Known VW hater
check the switch on the handle mine was sticking slightly on the passenger side could be the prob
Old Aug 11, 2013 | 02:27 PM
tim10_10's Avatar
tim10_10
Check the wiring as it goes through the door. Most likely a broken wire or two
Old Aug 11, 2013 | 04:04 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Have you checked the red connector behind the speaker cover in the footwell? If not pull it apart and clean the connector pins using a fibre pen. Should sort it pal, I tried everything and it worked for me.
Old Aug 20, 2013 | 11:28 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Mine sometimes unlocks, locks then unlocks again when i unlock using the alarm. Sometimes it forgets the last unlock so i have to use the key. Sometimes it just unlocks as normal. I thought it was the clifford and whatever central locking controllers they used with it.
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
