cosworth parts i can take to for fair
l8 ecu with pectel baby board £400
air injectors £250
antilag throttle body complete with idle valve and throttle switch £125
set used grey injectors £100
escort small turbo inlet plenum cover £100
2x pfo9 throttle switch £25 each
2x 044 fuel pumps used complete with fittings and filters £60 each
msd digital 6 plus ignition control used £125
baily type turbo damper has had repair £45
p8 pectel baby board issue 1 used £50
level 1 ecu £75
evolution level 3 chip for greens 3 bar standard comp £85
small coolant swirl pot £25
3 bar map sensor pipe has been glued,working ok £25
call or text mike 07734436787
air injectors £250
level 1 ecu £75
JoeyBoyden
Jan 4, 2024 02:36 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
