Rs turbo charging problem
Right Rs ain't charging.
The battery light isn't on
The battery when ticking over is reading 12.5v
Altanator is12.8v
New to this volt meter set to 20VDC?
Altanator is12.8v
Does the light work when you key on? Disconnect the blue wire and earth it with the key on, tests the warning wire circuit/bulb etc.
Check the wiring between the starter motor and the alternator, they can corrode.
If wiring ok, alternator is faulty.
You've got your meter on the right setting 20v dc.
My battery light comes on faintly with headlights... Even tho batt voltage is at 13+ and alternator is putting out nearly 14v?
Also my rev counter rises when theres alot of electrical load, its quite funny...
Any ideas?
Any ideas?
my revs rise and then it cuts out and needs jump starting
This is usually caused by old wiring which has resistance etc, thus increasing the load means even less power avaliable.
With the lights on, measure the power from say, the cigarette lighter, what is the figure, I suspect a discrepancy between that vs power @ the battery?
The warning setup is very basic to start off with and dosen't really tell you anything.
Martin
sounds like the brushes are slightly warn on your alternator should be about 13.8v
never hurts to check your earths though main one is on the front of the gearbox
don`t buy a new alternator fortunes now and i do alot of work for a factors
get it repaiered average price 20/30 quid
Tondeur
Tondeur
Not interested in a 2nd hand one, it'll b as old and worn out as mine probably...
http://www.ebay.co.uk/itm/Ford-escor...item5649aa746b
This has got to be the winner!?
Best way.
Phone local motor factors ask them where the nearest place is you can get a cable made up
Wip it off the car go in and they'll make you one in two minutes for under a tenner.
You can always up yhe cable a gauge too.
Tondeur
Tondeur
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Matt Baxter
Sep 16, 2015 08:30 PM
