NMS Series 2 escort rs turbo (87) !NOW BREAKING! FULL LIST ON RS TURBO PARTS
Old Aug 5, 2013 | 06:44 PM
Joe91's Avatar
Joe91
Default NMS Series 2 escort rs turbo (87) !NOW BREAKING! FULL LIST ON RS TURBO PARTS
NMS Spec 1600 cvh
NMS Head machined for 300bhp+ think it's stage 7..Newmans phase 4 fast road cam, solid lifters and single valve springs.
Robson engineering EN24T H section con-rods custom made to NMS specification, shot peened and fitted with ARP big end bolts.
Cosworth mahle pistons 0.75 oversize.
Block - cleaned, descaled and painted..torque bored for rebuild, block face decked, block face remachined to accept Custom NMS head stud conversion, essential for 300bhp+.
New modified oil pump, for high flow and high pressure.
Original sump blasted, cleaned and painted in 2 pac black paint.
Straight through 2.5" exhaust with 4" back box.
Pace single pass FMIC with twin fans
Custom radiator with copper core, from Tony's white erst.
Mk1 focus RS injectors
bosch 044 fuel pump
Omex 600 management
Garrett T34.48 turbo, rebuilt 1500miles ago by cr turbos. And new actuator
Vibratechnics engine and gearbox mounts.
300mm focus ST170 calipers and grooved disks
Zetec coilpack
Brand new battery
Brand new starter motor
Spec R header tank
Powder coated rocker cover with NMS logo engraved
Reverse charge carrier
Full samco black hose kit, apart from turbo to filter which is blue
Diesel mk5 box, been In the car for 6months and hasn't missed a beat, doesn't crunch at all.
Helix 4 paddle clutch.
Chassis:
I had this done at NMS when the engine was built,
New floor, sills and rear passenger arch.
Fully waxoiled underneath
Passenger door had rust taken out and resprayed also the scuttle panel
Polycarbonate front windows with sliders, 3 months old but are marked due to being marked very very easily. Have original glass and runners etc to go with the car
Poly bushed lower arms
Koni adjustable suspension on the front and standard rear.
Full new Braided brake lines
6 point safety devices roll cage, with all new welded mounts/plates for bolts.
Flocked dash also from tony turbo's erst, custom made for 3 defi gauges 60mm, also a 52mm gauge holder by the ash tray, 6 switches to be used for whatever you need, only 1 is used at the moment for high and low boost settings.
Carbon clocks in vgc.
OMP deep dish steering wheel.
Omex ecu lives in the glovebox for ease of mapping etc, also the car can be mapped by a plug by the switches
Standard rs turbo wheels in Volvo grey, starting to flake and have been a little chipped etc, didn't spend any money on getting them done properly.
Car is mapped to perfection by Karl at NMS, low boost setting is set at 18psi and high boost setting is set at 28psi.
Engine has covered 8000miles since being built, and 1000 miles since being mapped to 28psi.
I never thought I'd sell this car but the time has come to move on to something a little newer and 4WD, I have hundreds of receipts with the car, MOT's from the 90's and tax discs going back years.
I've spent over £15,000 on the car from buying it, ill never make it back but id like to see it live on, I may break it if there's enough interest but it's alot of hassle and slightly disheartening due to the car being setup very well as a package and having put all the time into it. The engine owes me about £10,000.
I have loads and loads of spares to go with the car, about £500 worth of spares if you wanted to sell them. Original dash, clocks, seats..everything apart from the carpet, which I'm sure you could pick up cheap enough. The car is totally stripped for lightness.
I'm a detailer so I do like to keep the car as clean as it can be but due to rust on panels etc it not immaculate, it gets a full detail every couple of months.
Bad points:
Someone reversed into me a while back with a tow bar and it cracked my front bumper and bent the intercooler in slightly, nothing has affected the performance of the car, it's not overly noticeable in a weird way.
passenger door had filler in it and is starting to crack, I do have another door to go with the car unsprayed.
The boot has some rust Round the edge of the window, The sunroof doesn't work, doesn't have a winder anyway because of the cage, the roof is a bit faded. Still have the roof lining in though.
The boot needs some small amount of welding which the pictures will show.
Apart from that its a nice all round car, im not going to make out its immaculate because its not but it is very clean. I'm being as honest as I can with it so people don't waste my time or there's.
The seat won't go with the car unless I get the right money for it..ill put the standard one back in.
It's a very good car for someone who has £1.5-2k to chuck at it to get the rust done and resprayed..All the underneath/chassis has be done and a very strong engine to go with it, would be the perfect car with a nice paint job.
It's an extremely fun and very very quick car.
Always run on 99vpower
PX with a diesel or anything, just offer and see what happens.
Price is £5250ono
As from now it has 11months MOT and 6months tax.
Ill add more as I think, there's so much to list.
Any of the above that was done by NMS can be confirmed by ringing them and asking about it.
Any questions please just ask.
Thanks, Joe
Old Aug 5, 2013 | 07:01 PM
Joe91's Avatar
Joe91
Old Aug 5, 2013 | 07:02 PM
Rst tyrone's Avatar
Rst tyrone
zetec turbo
any pics mate
Old Aug 5, 2013 | 07:12 PM
Joe91's Avatar
Joe91
Without poly windows:
Rotten sill and arch:
Brake lines:
Brakes:
I have thousands of pictures so if theres anything that i havnt taken one of, just ask and ill go get one.
Thanks, Joe
Old Aug 5, 2013 | 07:15 PM
Joe91's Avatar
Joe91
Some pictures arent so recent just incase you notice stuff there/not there in others.
Joe
Old Aug 6, 2013 | 09:37 PM
rsmark86's Avatar
rsmark86
Joe sorry to say it bud but if I was you I would break it
You will get less time wasters and a lot more money, you will struggle because of the climate at that price
BUT I think if you sell everything and take your time and not rush to sell it I think you will get what you want for it in bits
It's a great spec and only thing missing was a gearbox conversion
That tall block alone is a couple of grands worth at least
Old Aug 7, 2013 | 06:49 AM
Joe91's Avatar
Joe91
Thanks mark, I'm considering breaking it but its time and hassle, I'd love to see it still going as a car, I know not many people will spend that much on a car like this but I thought I'd give it a go.. I am open to offers however.
Yeah the engine is one of the best out there for a 1600 cvh, gearbox and coilovers would finish the car and make it a great car.
Joe
Old Aug 7, 2013 | 09:27 AM
The DIVA's Avatar
The DIVA
Looks mega that Joe if its anything like the van I bought off you it'll be even better than described !
Good luck with the sale mate
Old Aug 8, 2013 | 11:38 AM
rsmark86's Avatar
rsmark86
Just hold out with prices bud, it's worth it due to the spec
Old Aug 8, 2013 | 11:55 AM
HarryRS's Avatar
HarryRS
Got a Mk5 Golf GT TDI 55 plate full gti replica mate GTI leather recaro's sat nav
Just had waterpump and cambelt if your interested in a deal.
Old Aug 8, 2013 | 03:00 PM
Joe91's Avatar
Joe91
Hi mate, I don't really so replicas but send some pics to my phone or email if you can.
07702164925
Or
Joe.coughlin1@googlemail.com
Thanks, Joe
Old Aug 8, 2013 | 03:10 PM
HarryRS's Avatar
HarryRS
07702164925
Or
Thanks, Joe
I know what you mean bud! It's a diesel use it daily just in no need anymore so looking for a track toy. Sent you pics pal
Old Aug 8, 2013 | 10:08 PM
Pridzz's Avatar
Pridzz
Awsome car - cant believe its going, Had alot of time, Money and effort spent on it, Its had its ups and downs but at the moment its in its prime and worth every penny!
They say pictures sell cars so heres a few ive collected over the years..
Old Aug 16, 2013 | 01:59 PM
Joe91's Avatar
Joe91
Bump
Been on holiday the last week so I have replied to all pm's etc.
Thanks, Joe
Old Aug 16, 2013 | 07:49 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Gutted to see this mate but you have your reasons!
Hope all goes well with the sale...lovely spec'd car
Old Aug 16, 2013 | 10:01 PM
Its had plenty of money spent on it.
Old Aug 17, 2013 | 08:52 AM
Joe91's Avatar
Joe91
It has Glenn, try telling the person who has just offered me £3500 for it!
Thanks, Joe
Old Aug 17, 2013 | 08:57 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Sorry, but that Starlet looks the nuts!
Old Aug 17, 2013 | 09:15 AM
luke19790_3's Avatar
luke19790_3
Thanks, Joe
But if it needs welding and painting that's a good 2-3k that needs spending on it.
Worth more in parts.
Old Aug 17, 2013 | 10:05 AM
NC53's Avatar
NC53
If you decide to break it, I would be interested in the engine set up.
Old Aug 17, 2013 | 10:33 AM
Joe91's Avatar
Joe91
Dont think ill be breaking it bud sorry. To much time and effort gone into building it and i dont really have time or space to break it.
Joe
Old Aug 19, 2013 | 08:43 AM
Joe91's Avatar
Joe91
Price drop to £5250ono
Will consider anything in P/X
Joe
Old Aug 28, 2013 | 05:09 PM
Joe91's Avatar
Joe91
Bump.
Anything in p/x considered.
Joe
Old Sep 2, 2013 | 07:32 PM
Joe91's Avatar
Joe91
Default Now breaking
NOW BREAKING!
Havnt got time to wait around for it to sell as a whole so I'm going to break it, need most of the parts gone ASAP so any offers on stuff are welcomed just PM me, ill do a full list in the parts section either tonight or tomorrow evening.
Thanks, Joe
Billy_RS
16
Oct 11, 2025 09:41 PM
RsS2daz
Aug 14, 2015 05:26 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
adriansaleem
Aug 1, 2015 09:28 PM
