2wd shocks and springs ?
Old Aug 4, 2013 | 04:45 PM
tjRS500's Avatar
tjRS500
Default 2wd shocks and springs ?
Are all rear shocks and springs for a Sierra the same fitment?
What about the fronts ? Are all 2wd struts springs the same except cossy ?
Cheers for the help
Old Aug 4, 2013 | 06:49 PM
cossiedad's Avatar
cossiedad
Think cossies are different mate. Ride heights are definitely different as cossies are 15 or 20mm lower as standard. Hope it helps.
cheeRS
Old Aug 10, 2013 | 12:20 AM
viperz888's Avatar
viperz888
Yes, they are all the same on the rear, obviously differences between ride heights, but fitment is the same.
Pretty sure its the same for the front, other than the 2x4/4x4 difference.
Old Aug 10, 2013 | 10:52 AM
martysmartie's Avatar
martysmartie
All 2WD stuff is interchangable, however the Cosworth has a lower spring pan, so you will have to watch overall tyre size.
Obviously, as said, the springs can vary from model to model.
Martin
Old Aug 10, 2013 | 12:59 PM
tjRS500's Avatar
tjRS500
Cheers for the advice everyone
mark r
Sep 29, 2015 07:27 PM
RS-Rikki
Sep 21, 2015 07:27 AM
Topjoe9
Sep 12, 2015 09:50 AM
Adam Graham
Sep 6, 2015 06:04 AM
