Help with identifying brakes
Old Aug 2, 2013 | 04:59 PM
pikeyrs's Avatar
pikeyrs
Default Help with identifying brakes
Hi guys I'm after a it of help identifying what brakes are on my Rs. Previous owner told me they was Rs 2000 disks and calipers (front), but after removing one and measuring disc diameter they are 283ish mm, where as rs2000's are 270mm?
Also any ideas on calipers? I'm hoping they are cossie brakes and I've been misinformed lol
Any help appreciated thanks
Old Aug 2, 2013 | 05:17 PM
studabear's Avatar
studabear
283mm sounds like 2wd cossie front discs, they are usually matched to 4x4 cosworth front calipers. (single piston)
Old Aug 2, 2013 | 06:02 PM
pikeyrs's Avatar
pikeyrs
That's good to hear! Yes the calipers are single piston thanks for reply
Old Aug 4, 2013 | 09:48 AM
Ryoishikawa's Avatar
Ryoishikawa
Do they just clear standard wheels
Old Aug 4, 2013 | 01:47 PM
pikeyrs's Avatar
pikeyrs
Yeah just lol the reason I'm asking is my car has been sat around for a while and I took it for an mot. Car drove fine there and back,but it failed so I sorted work out and took it for re-test and n/s/f brake was sticking.
I removed calipers, checked that pistons and pads were not stuck (which they wern't) and grease sliders but they are still sticking slightly so I'm planning on changing discs, pads, rear shoes and brake fluid so hopefully that will sort it.
Old Aug 5, 2013 | 06:40 AM
studabear's Avatar
studabear
replace the brake hose at the sticky corner.
Old Aug 5, 2013 | 09:16 AM
pikeyrs's Avatar
pikeyrs
Would that cause problem? They are braided hoses both sides.
Old Aug 5, 2013 | 09:59 AM
studabear's Avatar
studabear
when hoses start breaking down internally they can cause the brake to bind.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
