Saph fuel tank removal
Old Jul 28, 2013 | 09:33 PM
RSCossieGaz's Avatar
RSCossieGaz
Default Saph fuel tank removal
Stripping everything off the rear end on my saph if removed the bolts that are holding the tank up and removed fuel pump pipe to the tank but how do you remove the fuel filler neck from tank?? Not removed one before so any help would be great.
Old Jul 29, 2013 | 11:50 AM
nicksaph's Avatar
nicksaph
fuel filler neck is just a push fit mate, plenty of wd then the tank should pull away from it when lowering the tank.
cheers nick
Old Jul 29, 2013 | 11:57 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I'm sure you undo the screw under the flap and the neck lifts down with the tank
Old Jul 29, 2013 | 06:11 PM
RSCossieGaz
Its a 4x4 saph i got and fuel flap is released by lever if this makes any difference
Old Jul 29, 2013 | 06:17 PM
ajamesc's Avatar
ajamesc
Is there a screw by the filler neck I'm sure there was in mine and I think some thing under the wheel arch trim? I dropped my tank out with the neck still attached
Old Jul 29, 2013 | 07:57 PM
RSCossieGaz
Yeah there was a screw securing neck under flap! Undid that and tank fell down
steerfromdarear
28
Jan 29, 2016 06:14 PM
FlashRS
Sep 14, 2015 12:36 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
ekjim
Aug 17, 2015 08:57 PM
taylora1409
Aug 12, 2015 12:06 PM
