How to release clutch pedal ratchet?
Old Jul 28, 2013 | 12:06 PM
ram's Avatar
ram
Has a large member
Default How to release clutch pedal ratchet?
Hi guys
need to re fit the clutch cable on my saph. but struggling to release the pedal ratchet so i can hook the cable on.
any pointers would be great!
Old Jul 28, 2013 | 03:33 PM
GVK.'s Avatar
GVK.
Lift the pedal up/wedge it up if no assistant, then pull the cable from the 'box end, should release the ratchet.
Old Jul 28, 2013 | 07:55 PM
Cossy Mike's Avatar
Cossy Mike
Yeah lift the pedal towards the seat and it'll release the teeth on the ratchet and pawl, hold it with your finger and pull cable out
Old Jul 29, 2013 | 11:55 AM
ram's Avatar
ram
Has a large member
Cheers!
Cable is completely removed at the moment, so assume i need to thread it onto ratchet first (should be easy i guess?) then give it a yank with the pedal fully up and should release it.
Old Jul 29, 2013 | 07:49 PM
Cossy Mike's Avatar
Cossy Mike
Originally Posted by ram
Cheers!
Yeah hook it over the top of the ratchet then let go of it. It'll tighten up a bit then press the clutch pedal down with your foot 3 times and you'll hear the teeth biting as it tightens up
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
