1989 2wd sapphire cosworth- SOLD
Passionford Thread Killer
Its a 1989 2wd sierra sapphire cosowrth in crystal blue. The car has done 77500 miles, but the engine has only done roughly 17000 miles since it was built in 2003 by M A developments.
Engine spec is as follows:
Mahle low compression pistons and ring set.
New big end and small end bearings.
Big end bolts all RP.
W.R.C multilayer head gasket.
High flow oil pump.
ARP stud and nut kit.
Re-worked head port and polished.
Bosch 044 fuel pump.
3 Bar Map sensor.
Dark green injectors.
Garret t34/48, this was re-built by cr turbo's less than 500 miles ago.
RS500 style intercooler.
Silicone houses.
Large K & N.
Bailey oil breather kit.
Bailey header tank.
4WD inlet.
Airtec alloy rad only been on for 2 months.
CW looms engine loom with intergrated fuel pump loom.
Full 3" mongoose exhaust system, majority of heat wrapped.
Recently had both the alternator and starter motor re-furbed.
Recent battery.
Renewed all earths/negs with a boat kit.
Group A coil.
Recent phase sensor.
Harvey Gibbs chip running 27psi dropping down to 23 psi as the revs increase, this chip is supposed to be good for 330bhp+.
The car has 6 months tax and 12 months mot.
Outside has had the 4x4 bonnet fitted aswell as boot and petrol cap, it does have the puller installed for these . Also has the x-sport Rouse splitter and is sat on Tsw Imolas 17x8 with new toyo T1r 215/40/17 tyres.
Brakes - 330mm radial mounted brembo 4 pots ( not cheap lug mounted focus rs items) with ds2500 pads front and vented 4wd rear brakes with new pads fitted. Braided hoses all round.
Suspension- Koni shocks with alhmed road spec springs recently new from r&b motorsport, polybushed throughout.
Interior is in good condition usual wear on drivers bolster. Has a pair of stack gauges, boost and oil pressure . Just fitted new tailor made car matts.
Just the bad bits now.
There are a few small patches of rust, both rear arches but it is not alot at all. Also round the sunroof there are 3 small patches.
Rev counter and indicators works when they want too.
The car is on a cat C from a shunt in 2004 , which is reflected in the price. This never bothered me as the body is straight and shows no signs of repair. The panel gaps are good and still has the original sealer at front panel to front wings .
located in poole, dorset .£4000.
No swaps thanks.
High flow oil pump.
3 Bar Map sensor.
Silicone houses.
Large K & N.
Bailey header tank.
4WD inlet.
Recent battery.
Group A coil.
No swaps thanks.
mike elsome
Sep 14, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
