clunking noise from the front
for the past couple of months theres been a clunking noise from the front end wen pulling away not too suddenly and coming off a kerb and if I come on and off the accelerator sharply, could this be the lower arm or ball joints
Just recently had a frustrating clunk from the front of my fiesta when pulling away and on lift-off.
I saw some chat on an Impreza forum about it coming from driveshaft hub nuts being loose, and sure enough when I checked mine was it turned very easily (I had the driveshaft replaced at a garage last year).
So I tightened it to a guess of 200Nm which was about 1/2 a turn or more and the clunking is now gone!
Just thought I'd give it as an idea.... it's an easy thing to check if you already have the big socket for the nut.
Nov 3, 2015 04:08 PM
Archiejay
Aug 12, 2015 12:07 PM
