2010 mondeo 2.2 tit x
Old Jul 25, 2013 | 05:45 PM
horse box's Avatar
horse box
Default 2010 mondeo 2.2 tit x
Hey peeps any ideas why my boost pipe keeps splitting.. on numbet 3 now and only 51k on the clock.
Old Aug 10, 2013 | 12:41 PM
black_jack's Avatar
black_jack
Black Jack
You may have a boost control problem like a faulty actuator or "sticky" VNT vanes
Thus increasing boost pressure and the strees on the hose/s
The oil from the breather can "melt" rubber so you could fit a catchtank
The realative movement between the engine/ chassis can put some boost hoses under stress - if an engine/ gearbox mount is worn - it can incresse this movement
Finally, an "aftermarket" "performance" hose may last longer than an OEM(Ford) one, because it may be tougher/ stronger and silicone does not "melt" (gradually) in oil like rubber does
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
