oil pan on sierra dohc 2.0 1991
Old Jul 24, 2013 | 09:15 AM
Mokum's Avatar
Mokum
Default oil pan on sierra dohc 2.0 1991
HI,
I'm french,
I fitted on my kitcat a 2.0 Ford sierra DOHC EFI (GB) 1990 or 1991
my oil pan is broken
Let me know if i'm wrong,
the oil pan on this sierra was made for a RHD
can you help me to find the good one (used or not)
If you can give me a website to find it
thank you for your help
best regards
Old Jul 24, 2013 | 09:19 AM
natehall's Avatar
natehall
There are two different oil pans on the standard 8v DOHC identifiable by where the starter is located. Looking from the front of the engine, which side is your starter motor?
Old Jul 24, 2013 | 09:29 AM
Mokum's Avatar
Mokum
i will check this afternoon thank you for your help
for clarify my query : 2.0 I DOHC (85 KW / 115 HP / FROM 1991)
Old Jul 24, 2013 | 09:47 AM
Mokum's Avatar
Mokum
Old Jul 24, 2013 | 10:06 AM
natehall's Avatar
natehall
Yes, for 100% clarity - does it look like this:
Old Jul 24, 2013 | 11:46 AM
Mokum's Avatar
Mokum
yes, but I don't know if the starter is on the right side or the left side
i will check it as soon as possible
Old Jul 24, 2013 | 12:17 PM
Mokum's Avatar
Mokum
the starter is on the left side
regards
Old Jul 24, 2013 | 12:43 PM
natehall's Avatar
natehall
regards
Ok,
Then in the UK market you are after a sump from an automatic. if the lump for the starter is on the left when looking at it from the front (distributor cap)
Old Aug 28, 2013 | 09:33 AM
Mokum's Avatar
Mokum
sorry for the delay
i was wrong, the starter is on the right side when i look the engine (the engine is on front of me)
Ford France tells me that the oil pan for sierra is the same for RHD and LHD
but i found this on internet...
http://www.fordopedia.org/parts-catalog/pinto-ohc/B3.20
anybody can help me
regards
Old Aug 28, 2013 | 09:38 AM
Mokum's Avatar
Mokum
Ford finis sierra rhd 1622645
Old Sep 2, 2013 | 07:22 AM
Mokum's Avatar
Mokum
i found this part
http://www.allcarpartsfast.co.uk/for...sy-engine-oil/
somebody can tell me if i'm wrong
Old Sep 3, 2013 | 04:46 PM
marky g's Avatar
marky g
You can get these brand new on eBay
I bought mine of there and was only around Ł30 for brand new deliverd
Old Sep 4, 2013 | 09:22 AM
Mokum's Avatar
Mokum
thank you for your answer but i haven't found any pan oil suitable for my engine
Old Sep 6, 2013 | 09:24 PM
mk22door's Avatar
mk22door
Fart of the Purniture
Your starter shoul;d be under the inlet manifold, as said above - in the UK you would require a sump from an automatic.
Ford of France is wrong.
LHD sump is same as UK auto.
Old Sep 6, 2013 | 09:37 PM
dojj's Avatar
dojj
Resident Wrestling Legend
search ebay for dohc granada as these were more likely to come with an auto box fitted
Old Sep 9, 2013 | 10:26 AM
Mokum's Avatar
Mokum
thank you for your help but I was wrong.
My sump is for an 2wd
Old Sep 9, 2013 | 07:47 PM
dojj's Avatar
dojj
Yup, most dohc sierras came in 2wd format
Old Jan 17, 2014 | 12:19 PM
Mokum's Avatar
Mokum
Any idea?
I don't find any sump for my engine...
Old Jan 17, 2014 | 06:56 PM
dojj's Avatar
dojj
there are only 2 sumps for your engine, the auto version with the starter on one side and the manual one with the starter on the other
can you take a picture of the sump from underneath the car?
i'm sure we can help you out
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
robbo9006
11
Sep 1, 2015 02:10 PM
andyrs1600i
Aug 30, 2015 07:21 PM
