Caliper Bolts working loose
Old Jul 21, 2013 | 09:04 PM
dickdastardley's Avatar
dickdastardley
Default Caliper Bolts working loose
Hi, just about finished my 3dr now just ironing out the teething troubles after a 17 year lay up. I have now after only 100 miles had to stop and retighten my caliper bolt on the o/s/f wheel on two occasions. Firstly wondered if anyone else had this issue and secondly i was thinking of re fitting using loctite just wondered if any other suggestions.
Old Jul 21, 2013 | 09:09 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
i would use loctite without doubt.
Old Jul 21, 2013 | 10:06 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
An just use a dab on one side of the thread or you'll never get them open again. If you ever want to remove caliper in future. Threads on bolt and caliper bracket look ok then?
Old Jul 22, 2013 | 07:33 AM
Mk4 Rick's Avatar
Mk4 Rick
As above loctite works well ive used it many times before
Old Jul 22, 2013 | 10:38 AM
studabear's Avatar
studabear
blue loctite, that should cure it unless the thread is damaged in some way.
Get some pics of your motor up.
Old Jul 22, 2013 | 10:46 AM
adam151082's Avatar
adam151082
Is it the correct bolt? Sounds like you need to put them tighter or the threads are knackered on the bolt or caliper
Old Jul 22, 2013 | 11:58 AM
dickdastardley
Thanks for all your replies. All threads ect all in perfect order, tightens up perfect but just seems to work free. I have never had this issue before and usually copper grease all fittings to help with removal later which is why i was unsure as to the use of loctite on something i know will cause me hassle later.
Would love to put some pics up but only seem to be able to put in my gallery but if any one can tell me where im going wrong i will add some.
Old Jul 22, 2013 | 08:11 PM
wrcjim's Avatar
wrcjim
never had to use lock tight on our competition car. but most road cars do use a lock tight, probably use red high strength locktight. blue locktight been standard.
we use a locking washer. wurth do a nord-lock washer which are really good.
shnorr washers work well too.
one thing to check is that all mating faces are free of paint. people think its a good idea to paint everything, heat from the brakes can coarse the paint to go soft leading to loose bolts
cheeRS
JIM
Old Jul 22, 2013 | 09:05 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Yea stick with blue locktite: notice it's only on one side of the threads. Hope this helps.
Old Jul 22, 2013 | 09:37 PM
dickdastardley
Old Jul 22, 2013 | 09:38 PM
dickdastardley
Tried the loctite today so fingers crossed
Old Jul 22, 2013 | 09:51 PM
M K's Avatar
M K
If not I'd lock wire them, 100% secure and easily removed
Here's an example of steering arm bolts
james kiely
Aug 28, 2015 08:58 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
