I need the whole bracket mate I have a frst under slung one at the moment on my zetec turbo but my external oil pump now gets in the way so need a over slung type which I believe comes on a mk3.
Can I also add that if its going on a blacktop with a lowering bracket a bit needs grinding off to clear the sump or it will make the alternator sit on the piss.
It won't be with a lowering bracket mate I need to raise the alternator (which is currently frst bracket and alternator) to clear a external oil pump I have I'll have to get one of these and modify it some how.
