Mk3 2.5 V6: Cam Chain let go
I was having a lovely day today. On my way home with the family when the idle went rough. Then a horrible noise. Then the engine cut out
I'm pretty sure it's the timing chain. Only done 65k and these things are supposed to last for ever.
Pulled the manifold - it has some wee bits of metal in it so something is FUBAR'd.
Pulled the front rocker cover. Head and chain looked fine. Must be the rear bank. Will take the rear rocker cover off tomorrow and survey the carnage. Next thing to do is pull the head. If the pistons are damaged I'm swapping in a new engine or breaking the car but if it's just the head I'll replace it.
How hard is it to pull the head? Looks like there's quite a lot of room to approach the exhaust manifold from underneath. I've got no manual - what order am I supposed to undo the head bolts?
Anyone got a spare head or even a whole 2.5 Duratec they want to sell me?
I'm also in the market for another Ford on a temporary basis until I get the barge fixed, must have 5 doors, be cheap and be in Scotland.
You and Chris are right - I can't even get the flipping cover off. One bolt is fouled by the engine lifting bracket. Can't take the lifting bracket off because the loom is in the way.
This is an engine out job whatever way you look at it.
Went and put a deposit on a 2001 LX 2.0 with a genuine 50k on the clock and a full service history. I rather think the Ghia is going to become a parts donor.
It's a shame, went like a Learjet
I've PM'd you about the manual
I bought the LX, and basically hate it. So will be fixing the Ghia as a project. Will remove the engine, get a good look at it, and then make the decision as to whether to fix it or swap a whole new lump in.
mk3ste
Oct 17, 2021 10:09 AM
Steve Escos
Oct 1, 2015 06:57 AM
