Swapping the fuel tank on my RS
Old Jul 18, 2013 | 06:35 PM
Si74's Avatar
Si74
Default Swapping the fuel tank on my RS
I have an almost new fuel tank to replace my rather tired original.
All looks fairly straight forward but I'm wondering about the main pipe from the filler cap into the tank, says sod all in the Haynes manual and from experience, I'm thinking it will be too much to hope for that the 23 year old seal will come out ok and then reseal into the new tank?
Any pointers appreciated.... this underside clean up seemed like a good idea at the time
Old Jul 18, 2013 | 06:47 PM
millybuzzin's Avatar
millybuzzin
Hi mate did mine a couple of years back had no probs using the original seal and its still ok
Old Jul 18, 2013 | 06:59 PM
Si74's Avatar
Si74
Cheers for that.
Wondering if all the silly wee clips for the sender wires, fuel pipes etc are still available form Ford as mines are all a tad rusty!
Old Jul 18, 2013 | 07:26 PM
millybuzzin
Replaced all mine with stainless steel clips i bought from a hardware shop near me
Old Jul 18, 2013 | 08:48 PM
rsmark86's Avatar
rsmark86
carefully remove the clips one by one before touching the tank, bit of penertrating fluid will do the trick
ive never changed the seal either, be worth taking the neck out after the tank to was the 25+yrs of road dirt out of that area while its out
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
grishenko45
Sep 9, 2015 12:58 PM
kevin36
Sep 8, 2015 12:23 PM
