Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
WTB Zetec 98-99 Mountune & WRC 2000-04 water pump housing
Old Jul 17, 2013 | 10:11 PM
focusracingaustralia's Avatar
Default WTB Zetec 98-99 Mountune & WRC 2000-04 water pump housing
I'm looking 2 different types of water pump housing for my Zetec 2.0L 98-99 Mountune block and 2000/04 WRC block
Both water pump housing bolt holes are 3 bolt.
How much for a water pump and housing cost?
And yes I ask M-sport and NO they couldn't help me like always.
[IMG]tmtb://tmtoolbar/en-us/SRResource/webicon_green.png[/IMG]http://i218.photobucket.com/albums/cc283/FocusAngel/Snapbucket/3C811471.jpg
[IMG]tmtb://tmtoolbar/en-us/SRResource/webicon_green.png[/IMG]http://i218.photobucket.com/albums/cc283/FocusAngel/P6250685.jpg
Rob
Old Jul 22, 2013 | 03:47 PM
AustenW's Avatar
AustenW
The silver top engine (early engine) block was not used in WRC so all you can use is the std oem waterpump that fits in your block. they used the std pump anyway.
The blacktop WRC block as pictured was modified with a pear shaped hole in the side to assist flow
They have a round hole as standard
The WRC engine used a regular ford water pump that was welded and machined to match the pear shaped hole. It had an o-ring groove machined round the mating hole of the pump to seal it. Other than that it was pretty much a standard Ford Item.
How do I know? Because I bought of the last ones from cosworth and used one on my own engine.
Cosworth originally developed the Focus WRC engine but lost the contract to mountune.
If you are using the black top WRC engine I would use the later OEM Focus RS water pump
This was not available during the WRC days but was brought out for the Focus RS road car a bit later on.
It uses a much larger housing and impeller to cope with the added heat of turbo use.
I bought a new Focus RS pump from Ford and had it welded and machined to an oval to match the block
I also had it o-ringed at the same time to make it seal nice.
Either way a standard waterpump from your local ford dealer should be your starting point.
Old Jul 22, 2013 | 03:52 PM
AustenW's Avatar
AustenW
This is a later WRC water pump on my engine
Modified Focus RS Pump Below
Old Dec 17, 2013 | 06:26 AM
I can't find any RS water pump housing that will fit the WRC Zetec Mountune block.
The stock water pump has a hole of a 20 cent piece and I need a hole the size of a drain pipe.
Old Dec 17, 2013 | 06:39 AM
Would this work
http://www.ebay.com.au/itm/00-04-2-0...item3366aaeaea
JK12
33
Apr 26, 2021 12:09 PM
mrknifey
Aug 30, 2015 11:48 AM
cameron2
Aug 25, 2015 07:18 AM
Dubs44
Aug 21, 2015 02:42 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
