Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Which Rear Pads for ST225?
Old Jul 16, 2013 | 09:41 PM
Bubble Meister's Avatar
Bubble Meister
Default Which Rear Pads for ST225?
I have a 06 plate ST2 225. From the internet Iv ordered Motorcraft new discs and pads all round. The front is sorted and the rear discs appear correct but Im struggling with the new rear pads. The ones I received are 1809259. When I went to fit them the little spigots wouldn't fit in the piston holes. The spigots on the pads are too far apart. This is the same on both sides.
Today I went to my local ford dealer and he checked the parts catalogue against my reg plate - he agrees that this is the correct part no - he even got another set out just to make sure the ones id received weren't incorrectly labelled.
Apparently the part no supersedes a variety of part nos. One of the old nos is 1753860. It just so happens that tonight I noticed on my delivery note that this was the typed number. Somebody has crossed it out and written this 1809259 number on.
When I removed the old pads I noticed that they had been fitted incorrectly with the piston pad on the outer side and the vice versa. This makes me wonder if I have the wrong calipers or something. On the N/S caliper all I can really see clearly is 987 cast in. They are ATE calipers.
Can anyone shed some light on the matter as I would prefer pads with spigots that sit snug in the piston?
Cheers folks
BM
Old Jul 17, 2013 | 05:36 PM
Bubble Meister
I've done some measuring. The distance between the holes on the piston is approx 19 mm centres. The distance on the pads is approx 22mm centres. Both ford n myself are baffled. Maybe i have after market calipers fitted.
Old Jul 20, 2013 | 10:14 AM
Bubble Meister
I have mixed messages from Ford: I have rang a number of Ford dealers. Some believe the pads don't have to sit in the piston and that the holes in the piston are purely to retract the piston. Other garages believe the pads should sit in the piston!!!
Confused!!!
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
155lee
Sep 6, 2016 11:10 AM
yatta
May 21, 2016 10:31 PM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
