Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Sudden loss of coolant + another annoying problem
Old Jul 13, 2013 | 10:59 PM
paulus90's Avatar
paulus90
Newbie
Exclamation Sudden loss of coolant + another annoying problem
Ive owned my focus for 12 months now and the coolant has dropped like 2mm in that time. now all of a sudden i check my car today to find i had lost over a litre! i topped it back up and its dropped slightly already but there are no wet patches on the road under my car or on anything under the bonnet. where is it all going ?! theres no white gunk forming inside my rocker cover and the oil is still jet black so i dont think its the head gasket. heater matrix is possible but the footwells are bone dry. can anyone help?
also when i start my car i can hear a tappy scratchy kinda noise coming from the engine bay when the engine is idling and it makes the sound more frequently when i rev the engine relative to the revs. it goes away after a short while but it does not sound healthy at all. its not squeaking like a drive belt, more of a tapping noise which wasnt heard before a couple of weeks ago.
any help would greatly be appreciated. apart from this. My focus is the most reliable car i have ever owned and id definitely buy another!
Old Jul 14, 2013 | 06:03 AM
uruk hai's Avatar
uruk hai
What engine does it have ?
Old Jul 14, 2013 | 08:03 AM
paulus90's Avatar
paulus90
Newbie
1.8 16 valve zetec petrol.
Old Jul 14, 2013 | 08:21 AM
justin st13's Avatar
justin st13
Check the seal in the thermostat housing. Mine done that an the seal was shagged. ( ford said it a common problem) mine a st170 but could be the same problem. Worth a check. But only ford sale these o rings
Old Jul 14, 2013 | 08:22 AM
justin st13
As for the tapping noise, maybe a bearing or something
Old Jul 14, 2013 | 08:32 AM
RichieST's Avatar
RichieST
oil should be brown, not black. When was it last serviced?
Old Jul 14, 2013 | 09:34 AM
uruk hai's Avatar
uruk hai
That's what I was going to suggest but without knowing the engine type it would have been guess work. As said the gasket around the thermostat housing can leek quite badly but it usually gets boiled off so you hardly ever notice it !
Old Jul 14, 2013 | 08:22 PM
paulus90's Avatar
paulus90
Newbie
the oil has a brown look to it yeah so i know the oil is ok. as for the coolant leak ive found the problem. its leaking out of the lid. i understand its meant to release after a certain ammount of pressure and i know i have no overfilled the system. could the lid be no good?
as for the scratching noise i will record it and post it here.
Old Jul 14, 2013 | 09:22 PM
uruk hai's Avatar
uruk hai
Originally Posted by paulus90
could the lid be no good?.
There is a chance it could be the lid and as it won't break the bank I'd buy one and see what happens, either that or you could get the cooling system pressure or sniff tested ?
Old Jul 14, 2013 | 09:46 PM
paulus90's Avatar
paulus90
Newbie
tbf mate ill just buy a lid. the car cost me 120 quid and looks like a shed on the outside. not gonna dig too deep.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Botts
Sep 22, 2015 02:04 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
tib2220
Sep 14, 2015 12:33 PM
natehall
Sep 8, 2015 05:13 AM
