Parts needed for my Saph TRADERS PLEASE
bulkhead rubber seal
washer bottle pump for headlights
o/s headlight wiper motor
n/s/r outer window rubber
carbon fibre fog light surrounds
WHY
Many thanks
Moanstone Steve
WHY
Many thanks
Moanstone Steve
There are at least two types of plugs on them mate, for the motor
Some are round and the later ones were square or triangular
I'll pop some in the post if you send me your address and hopefully they will be the right ones
Hi mate yh I've got the n/s/r outer seal it gas a little bit of over spray on it that will clean off but no corrosion so in good nick mate got the pump for headlights with the pipe too just got to power it up the bulk head rubber is that the bit that's about a metre and a half long and goes from behind the battery across to the fuse box? If so I have that now just got to check the loft for the wiper motor
155lee
Sep 14, 2015 07:37 PM
155lee
Aug 14, 2015 11:21 AM
