escort rs turbo s2 amail
The amail valve on a rs turbo s2 where do the pipes go to and I've got a water cooled turbo does anyone know were the 2 water pipes go to or has someone got the water pipes for sale
Cant remember the Amal valve, but I think the water pipes are- top water pipe goes to thermostat housing and bottom goes to the o/s rad.
You can run without water pipes just make sure you let the car idle for a few mins before switching off.
Dan
Dan
U can bridge the two water pipes together top to bottom if u have a air cooled turbo, just by a joiner, easily done, Amal valve comes from map sensor to actuater I think, ecu runs pipes to map sensor and the Amal valve n bleed valve r usualy between actuater n map sensor
1 nearer to the rad goes to the rad return mate an top 1 goes to top rad hose mate!
Top one shud plug into the pipe that goes from rad into water thermostat just under dizzy, it shud have a thin pipe that pushes over the long tube on top of turbo,
Had too much booze n sunburnt
Let it tick over for a min or two after driving hard anyways,
Let all the oils and water pump round engine and turbo,
Always warm her up before ragging it as cool her down before switching her off
I have same prob previous owner put a charge cooler on but never plumbed it in and the water pipes are missing someone told me don't bover putting them on because it will run cooler because hot water from the turbo won't be circulating around the engine so don't know what to do everyone's saying diff things
Yes same problem different answers from everyone I do know someone who has been running his over a year without any problems he told me s1 didn't have water cooled turbo and both are the same turbo unit I just don't know?????
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
