rev problems
Old Jul 10, 2013 | 06:04 PM
jimhc's Avatar
jimhc
big jc
Default rev problems
i had a problem with hunting the revs were brought up to 1000rpm which solved the problem last week now i found a cracked pipe going from 3bar to inlet. i replaced it at work and this dropped the revs down to 800-900rpm so i was happy then i left work and noticed when i take my foot off the throttle the revs creep down slowly below 2000rpm have i done somthing wrong or has anyonee else had same problem??
Old Jul 10, 2013 | 10:22 PM
jimhc's Avatar
jimhc
big jc
if i unplug the idle control valve the revs go down normally
Old Jul 11, 2013 | 06:35 PM
-=Cossie=-'s Avatar
-=Cossie=-
Had exactly the same problem as you mate, my car is 2wd on l6, all i did was adjust co screw anticlockwise 2 turns to richen idle mixture slightly and it cured it.
Old Jul 11, 2013 | 10:08 PM
jimhc's Avatar
jimhc
big jc
my car is over fueling as it is.
Old Jul 12, 2013 | 07:46 AM
jimhc's Avatar
jimhc
big jc
I was told to adjust the screw under the throttle body when the idle control valve is unplugged. Adjust it so the car almost cuts out then plug the ICV back in. But this has just made the car hunt and the revs still drop slowly not the way they should.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
