Is the cosworth shell same as a gls shell?
Its unusual that there is not some small difference somewhere on shell to identify it as an original cosworth. I suppose it says something about the basic shell, that it did not need extra strengthening to cope with the extra power.
IIRC correctly only the 4x4's had strengthening up front for the power now going to the front end as well as the back and obviously a bigger tunnel for the transfer box and cut outs for allowing the front drive shafts not to hit the chassis when front end going down due to braking/cornering.
A 'Cosworth' is merely a Sierra, the 3DR is a base model with a bodykit
The Escos is bespoke and only shares 3 panels with lesser models.
In the case of a Saph, it's exactly the same, the 4x4's differed, as said in that they had extra strengthening in the front wings and 'notches' cut into the shell, although all late shells had this anyway IIRC.
Martin
Martin
Thought I read somewhere that the Cosworth was a Ghia shell and there was a difference with the bulkhead due to air con or something??
Surely you could get a GLS with a/c though?
So with that in mind it may mean there are specific A/C shells? Remember on the 4x4's A/C was an option, as was it with lesser models.
Martin
Which is why they have to be spec'd from the factory as being ac or they will just use a normal shell (pre 90 spec was also variable with being 2wd or 4wd or the tunnel and chassis notches)
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
rog
Sep 4, 2015 12:10 PM
Aug 14, 2015 07:29 AM
