Ka Sport loss of power?
Hi All Recently I picked up a little Ka Sport 04 plate which is great fun to drive, although a little juicier than I thought it would be But it has developed a strange fault and has lost a lot of power , Finds it hard to rev past 3k and sounds like its struggling to pull in air?? really loud front end noise but no going power I changed the Lambda sensor after some Googe searches but this hasnt fixed it, So I had a friend plug it into a fault reader which showed no fault codes, he noticed on the live data that the inlet valve flaps were not active.... ?? Tried a quick google which hasn't shown up much so wondering if this sounds like a common problem? If not any thoughts ideas would be a great help Thanks Nick
Great fun to drive sounds like you may have caned it, but i could be wrong of course...
Its juicier, lost power, doesnt rev up properly, lots of front end noise.
If it sounds a bit like a tractor, replace your hydraulic lifters in the head. If they failed, (over-revving is a killer for lifters and will prematurely degrade them at best) they wont retain engine hydraulic pressure any more causing them to open up a massive gap between the camshaft and the valve stem itself, creating lots of metallic impact noise. This fault will cause a lack of throttle response and lose power and economy due to a lack of incoming or exhausting fuel-air mixtures. Maybe even bad enough to limit the revs down to 3k or so by means of mechanical gas flow restriction (lack of valve lift). If its left and still thrashed, something inside wont like the continuous rapid impacting and will probably give up on you with very inconvienient timing.
In an internal combustion engine we have inlet valves, and exhaust valves, (both are inside the head) but not flap valves, which limit airflow to going in one direction. The air only ever passes through an engine in one direction, and so there is no need for a flap valve. It would be redundant. So i hazard a guess at saying there just isnt one attached to your car. Let alone saying its not active! On the flip side, if the inlet valve is the object in question, it still doesnt make sense because inlet valves are "one piece" and look like a 5inch rod or so, with a flat bottomed foot. No moving parts here, least of all, a flap attached to it.
Lifters could cost you £10/15 each or something, they vary.
Also check -
Spark plug electrode gaps. (should be 30thou +/-2 with feeler guages)
Throttle position sensor. (wires should read correct values at idle position and wide open, if not, relocate the sensor or replace it if the figures are not consistent)
Ignition timing. (Shine a timing strobe gun at the bottom pulley, connecting it in loop with plug no.1, and check that idle speed is operating with a correct amount of advance over the top dead centre mark, blipping the throttle should see the timing mark move towards the back, further advanced, while it accelerates and see it go the other way, retarded, when it decelerates, returning to normal at idle. If it doesnt this will cause major power losses and ignition control needs replacing)
Compression. (screw a guage into the spark plug hole and crank it fast without any other plugs fitted, open the throttle too to get maximum air into the piston for testing high pressure leaks)
Also check -
One more thing...
Check the throttle body air-bypass screw. It allows a metered amount of air to get past the butterfly when you've allowed it to close completely with idle throttle. The idle speed control valve is involved here aswell if it has one fitted and it should be thoroughly cleaned and checked for freedom of movement. No sticky valves allowed! It could cause the fuelling to be adversely affected and screw up the throttle response, perhaps even making it stall on its own from time to time.
Hope it helps
Hope it helps
Check the exhaust system. If the cat internals have broken free it can rotate and block exhaust gases. I had an escort gti which done it, would'nt rev past 3k and the induction noise became very loud.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
