Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
2001 Ford Fiesta Clutch/Gearbox issues
Old Jul 4, 2013 | 05:42 PM
etaylor12's Avatar
etaylor12
Unhappy 2001 Ford Fiesta Clutch/Gearbox issues
When the clutch is depressed with any gear selected, I can hear a metallic rotating noise coming from around the bell housing.
When setting off in first gear, the car shudders but once the clutch pedal is fully disengaged the car appears to drive normally, albeit a bit difficult to change gear.
The car is a 1.3 2001 Ford Fiesta Flight. I hope you can help me!
One garage said it could be a bearing in the gearbox.
Another garage is fairly confident it is the clutch.
Old Jul 11, 2013 | 02:12 PM
perry3188's Avatar
perry3188
Seen this problem a few times with ka's. I'd put money on it being the clutch. The pressure plate snaps leaving the centre of it rattling about. It cant go anywhere but just makes horrible noises when the pedal is depressed. Even if it were the bearing you'd need to take the box off anyway and its not worth taking a box off for a bearing and not replacing the clutch at the same time.
Old Jul 23, 2013 | 09:53 PM
etaylor12's Avatar
etaylor12
Do you think I'm alright to drive it while it's like this or could it cause more damage? It sounds exactly as you've described! Thank you for your reply!
JoeyBoyden
Jan 4, 2024 02:36 PM
druidgetafix
Aug 15, 2015 10:22 AM
Botts
Aug 13, 2015 04:16 PM
