what is the largest size tire can be fitted to front of a 3 door?
Hi Mates,
I am looking to see what diameter and width of tires can be fitted to front of a 3 door? I have adjustable tcas and compression strut front suspension with coil overs front suspension. The strut bodies are setup for 2.5 inch I'd springs. I have a set of eibach barrel XT 10 inches in length with 300 inch pound linear rate with the correct amount of travel to match my custom bilstein inserts.
This will be on a Merkur XR4Ti and it will be using Outcast Fabrication wheel flares and modified fenders.
I was hoping to run 225 40 18s.
Thanks,
Tony from US.
Thanks,
Tony from US.
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
