rear gaz coilover s help
Old Jun 28, 2013 | 08:57 PM
DAN400's Avatar
DAN400
Default rear gaz coilover s help
right I fitted a set of these yesterday and the car seems to be very bouncey
I tweeked about with the damping adjuster but its still the same,
what you guys think??
Old Jun 28, 2013 | 09:25 PM
KSA-Cossie's Avatar
KSA-Cossie
What poundage spring did you get ? I set mine 4 clicks from soft with 180lb springs and its perfect
Old Jun 28, 2013 | 09:36 PM
DAN400's Avatar
DAN400
not sure tbh ,
the guy I got them from said it was what gaz recommended, 225lb he thought,
got them off here a last week,
maybe take the springs out and get them tested
Old Jun 28, 2013 | 10:25 PM
BRAMMER's Avatar
BRAMMER
I spoke to GAZ early in the week and the GHA kit comes with 350 front and 200 rear - i had issues with mine as i believe there no happy medium with them but was advised 8-10 clicks max.
On my old rims i ran them completely off damper and the car was fine on the road
Old Jun 29, 2013 | 09:41 AM
DAN400's Avatar
DAN400
i ll have another play about with them today and see what happens,
cheers lads
Old Jun 29, 2013 | 11:17 AM
Harris.'s Avatar
Harris.
I had GAZ coil overs on my car , 2 days later I took them off as they were terrible on the road . I now have Koni's with bayjoo springs .No driver spot on .
Old Jun 29, 2013 | 12:42 PM
KSA-Cossie's Avatar
KSA-Cossie
I find my coilovers better than my old koni/bayjoo set up
Old Jun 29, 2013 | 06:27 PM
DAN400's Avatar
DAN400
Well I tweaked about with the settings today and I'm glad to say the car now drives spot on
They were just set far to hard,
So I softened them fully then gave them 3 clicks in ,
happy days cause the car badly needed lifted at the back as it sat to low IMO ,
Now there s oil leaking from my supra diff
The joys of cossie ownership
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
cossirob
Sep 3, 2015 09:17 PM
