Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
water leaking from dashboard
Old Jun 27, 2013 | 06:32 PM
Daniel-1986's Avatar
Daniel-1986
Default water leaking from dashboard
when either washing the car with jet wash or heavy rain, there's water dripping in the passenger side foot well, its a mk1 focus any ideas where it could be coming from?
Old Jun 27, 2013 | 06:44 PM
paulsheerin's Avatar
paulsheerin
Probably leaking in around the pollen filter. As far as I remember this was a common problem on the focus
Old Jun 27, 2013 | 06:47 PM
Daniel-1986
would getting a pollen filter seal sort the problem out
Old Jun 29, 2013 | 06:26 AM
uruk hai's Avatar
uruk hai
If the pollen filter cover is damaged or the clips broken you'll need another one, I'd take the cover off, the filter out and give it a really good check and clean. When you put it all back together make sure the windscreen is spotless where the seal sticks to it and that all the clips fit properly and tightly.
Good luck
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
