Cosworth TDC crank sensor help
Old Jun 23, 2013 | 10:06 AM
delbee1's Avatar
delbee1
Default Cosworth TDC crank sensor help
I brought all new sensors from MSD all went in fine except the TDC sensor.
I've tried to gap it but with max adjustment still is more than 1mm, tried the old sensor and that's the same too
Any suggestions??
Old Jun 23, 2013 | 11:00 AM
Stu @ M Developments's Avatar
PassionFords Creator
Your going to have to drill out the bracket to slot it further as it sounds like the wrong one for the sump.
Old Jun 23, 2013 | 05:21 PM
delbee1's Avatar
delbee1
Thanks I'll give it a go
Old May 15, 2022 | 11:46 PM
kcm's Avatar
kcm
Default Sensor bracket issue
I just got a TDC sensor bracket from a UK supplier and when I installed it the centre of the sensor was about a quarter inch forward of the pulley mark. I have a 4x4 block and a 2wd crank case/sump. Are there different sensor brackets? If so where can I source the correct one?
jayjay
Dec 29, 2009 07:52 PM
daveugc
Oct 11, 2007 04:37 PM
dean erst
Sep 11, 2006 05:27 PM
SteveB
Jul 9, 2006 03:34 PM
