Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Focus ST 2.5 boost problems
Old Jun 22, 2013 | 09:28 PM
Trevor82012's Avatar
Trevor82012
Default Focus ST 2.5 boost problems
Hi,
I hope someone can help with my problem.
Firstly, I have DSCI cold air induction, big intercooler, and a Blue Fin remap.
My ST use to boost to 1.2 bars (18 lbs). Now I am getting max 8 bars (10 lbs). I am also getting a different sound from the turbo now. A zzzzzzzzzzz sound. No the car is not falling a sleep .
I checked all boost hoses and they are good. Vaccum is about 20. This is good.
The Symposer canister diaphragm was busted so I removed it and blanked off the hose next to the Bailey blower valve I installed.
Can someone tell me if these symptoms are for a faulty Boost controller solenoid. Or what else can cause the boost problems.
Thanks.
Old Jun 22, 2013 | 09:34 PM
RichieST's Avatar
RichieST
Try taking off the dump valve, they do give a lot of problems.
Old Jun 22, 2013 | 10:27 PM
Trevor82012
Hi Richie St.
Yeah, Did that also no change.
If it is the Boost Controller, any one knows if the below is ok? Its for sale on Ebay.
IPD Uprated Turbo Boost Control Solenoid Valve
Old Jun 23, 2013 | 07:19 PM
mikej857's Avatar
mikej857
You can fit an ipd but some have had problems with these so I'd go with another standard ford one tbh
Old Jul 2, 2013 | 09:43 AM
Rudders666's Avatar
Rudders666
ST330 :D
It's almost always one of the three. MAF, MAP, Boost Solenoid
Old Jul 2, 2013 | 01:36 PM
Trevor82012
Well, Yesterday I received the three sensors in the mail. I changed the BCS and still not getting full boost. Today I will change the MAP and I'll let you guys know how it works.
I am trying each one separately, so I can identify the main culprit.
Old Jul 2, 2013 | 01:56 PM
RichieST's Avatar
RichieST
Have you checked for fault codes with your Bluefin handset?
Old Jul 2, 2013 | 03:03 PM
Trevor82012
When I bought the car it came with the Blue Fin and for some reason, I am unable to access the diagnostic part of the blue Fin.
Old Jul 2, 2013 | 03:08 PM
Rowe's Avatar
Rowe
Skint
Might be worth giving them a bell?
Usually when they don't work it means that the fuse has blown on the odb, the handset is locked to another car, or the handset has the wrong strategy coding to communicate with the ecu.
Old Jul 2, 2013 | 03:29 PM
Trevor82012
Rowe,
Its worth a try.
Thanks mate. I will do that.
Old Jul 2, 2013 | 05:52 PM
locum8's Avatar
locum8
Not 100% sure, but i think You can only access the diagnostic and immobiliser part of bluefin if you have registered the handset online with superchips.
I had to do this with mine to access it.
Old Jul 3, 2013 | 03:39 PM
Trevor82012
Hi Guys,
Just an update, I changed the MAP sensor and still the same problem, low boost.
I will change the MAF later today. But, I do not think this will make a difference with Boost.
Old Jul 15, 2013 | 05:32 PM
Trevor82012
Hi Guys,
I did further checks. I took out the Turbo, it looked fine, but the exhaust manifold was slack. I re-installed and the ZZZZZZZZing sound has stopped. Still low boost. But now I am seeing an oil leak from the exhaust Camshaft seal. I must replace both cam seals before I go further. I also took out the intake plenum and sealed it properly. Hopefully this should the boost problem.
By the way, does anyone know the Camshaft and Crankshaft timing marks.
Old Jul 18, 2013 | 11:34 PM
mouldytbags's Avatar
mouldytbags
you might have a faulty actuator? and get rid of the dump valve.
Old Jul 19, 2013 | 08:29 AM
Rowe's Avatar
Rowe
Skint
Hi Guys,
once you take the pulleys off the cams you're buggered. you have to use a special tool unfortunately.
If you leave the pulleys on, there are marks on the plastic cover and the pulleys themselves (they're very faint though)
crank mark is behind the pulley wheel for the aux belts. Think its a 30 or 32mm nut
Old May 31, 2014 | 07:11 PM
leedsrhinos126's Avatar
leedsrhinos126
Hi did you ever get this problem sorted? Mines buggered atm with same symptoms.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
