Fiesta RST EFI advice
Hello all,
This is my first post so please be kind
I must tell you I run a kit car but run this engine.
I have just tweaked my turbo actuator the car is now holding 1 bar of boost
Car is running a Fiesta RST engine.
The car has a T3 turbo, yellow injectors, a superchip on the ofac ecu, 3 inch exhaust,upgraded fuel pressure regulator.
From what i have read 15psi is max boost on the stage 2 chip, can anyone confirm this?
And also would the stage one chip cause a fuel cut at 12psi?
Thanks John
Thanks John
JK12
33
Apr 26, 2021 12:09 PM
