What diameter is FRST fuel line?
Old Mar 17, 2005 | 02:57 PM
heeman10's Avatar
heeman10
Default What diameter is FRST fuel line?
Am I missing any hoses out? I think I need fuel hose from the tank to the fuel rail (pressure regulator) then hose from the fuel rail draining back to the tank. Are they they only fuel lines I need, and are they the same diameter? I need to know what internal diameter they are...1/4", 3/8", smaller?
Old Mar 17, 2005 | 03:14 PM
Lee @ Fusion's Avatar
Lee @ Fusion
8mm internal bore mate ,
think thats 1/4 ish
Old Mar 17, 2005 | 03:49 PM
Scottish Greg's Avatar
Scottish Greg
Same reply with me as on FT.com ...
buy nylon fuel lines in stead of rubber
Old Mar 17, 2005 | 04:00 PM
heeman10's Avatar
heeman10
Thanks for the replies guys
Lee - Still no word back from Wilwood about the caliper thread sizes
Old Mar 17, 2005 | 04:19 PM
Lee @ Fusion
Syntec do a relativly cheep stainless braided hose , looks the nuts with hose finishers ,
when i re-pipe a car i use metal pipe from all good motorfactors , comes in a coil same as break line does , is bent by hand to follow vehicle contours and just use rubber fuel hose to connect each end to the appropriate place , fuel rail , regulator , tank etc ,
Old Mar 17, 2005 | 09:45 PM
JimmyRS2005's Avatar
JimmyRS2005
Ah right good thinking, forgot all about metal pipe! I'll send my car on down and you can do it for me while I bumble around here at uni
Old Mar 18, 2005 | 06:01 PM
heeman10's Avatar
heeman10
Dammit. The problems of having two login names!
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
CrOwSoN15
Sep 10, 2015 07:33 PM
focus2351
Sep 9, 2015 09:33 PM
