Ford 6000 radio help?!
Jun 10, 2013 | 07:09 PM
How do you adjust the default volume setting on the ford 6000 radio as mine is stuck on plus 5 every time i turn it on or start the car
Any help?
Jun 10, 2013 | 08:54 PM
normally you can only set the volume level when TA is activated, try holding menu button to see if there is a preset on normal volume setting
Jun 10, 2013 | 09:00 PM
Quote:
Originally Posted by
1-PD
You can put it on TA up but it won't go down any lower than plus 5 which is the default volume setting that I need to adjust
dojj
Aug 25, 2015 06:56 PM
Daisychain
Aug 22, 2015 08:12 PM
borboyous
Aug 22, 2015 11:17 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
