Ford Range This section is for other models in the Ford range.
Mk6 Escort PATS transceiver - do I need to get keys coded when replacing?
Old Jun 10, 2013 | 06:31 PM
Rune's Avatar
Rune
Default Mk6 Escort PATS transceiver - do I need to get keys coded when replacing?
Got a car that won't start because of what's according to the auto-electrics guy I had out a faulty pats transceiver, his diagnostics gizmo reported something like 'No response from PATS transceiver' ... can't get much plainer than that
The car is a 1998 Escort Estate 1.8 16v Gti
I understand it's not quite as simple as just getting a replacement transceiver but I might need to get it 'coded' into my car/keys?
There's a same part number transceiver with key on my ebay watch list (no-one else bidding on it -fingers crossed!), I'm wondering if there's any way I can avoid taking it to ford's and getting it 're-coded' as I've seen some info on the web saying I'd need to do
Anyone know if there's a way around it like maybe swapping the chips in the keys over? (Or any other bright ideas)
Also, shouldn't any auto-locksmith be able to do any key coding that's required?
Could I even do it myself?
Old Jun 10, 2013 | 06:34 PM
Rune's Avatar
Rune
I should have put this in the technical Q&A section, would someone be able to move it please?
Old Jun 12, 2013 | 04:40 PM
Rune's Avatar
Rune
I think I might've struck gold
Found someone selling a 'set' off a same year gti containing both door locks, boot lock, petrol cap, ignition barrel, one new style remote central locking key, transponder ring, and ecu
Forty five quid ... gotta be a bargain!
I believe I should just be able to swap everything over and bob's yer uncle, will need to get a spare made but that's a minor issue
Old Jun 12, 2013 | 05:03 PM
marc_gti's Avatar
marc_gti
you need the "pats" ring that goes around the ignition barrel, and also the ECU, keys and locks as a set to do it properly. this will be cheaper than getting it "reset"
the set you mentioned above should do the job fine
Old Jun 13, 2013 | 07:55 AM
STeve's Avatar
Super Moderator
easy job will take you 90mins tops to change over everything, hardest job is to remove rivet holding ecu cage onto passenger side footwell and thats no real biggy
Old Jun 16, 2013 | 12:15 PM
Rune's Avatar
Rune
I'd already taken the ecu out when first investigating this to check if there was any corrosion etc on the ecu contacts
There wasn't any rivets needing drilling out, just a bolt holding it in place (could have been taken out in the past maybe)
The kit I ordered should be here monday or tuesday so by wednesday I oughta know if it's done the trick
Old Jun 16, 2013 | 12:47 PM
doga-ot's Avatar
doga-ot
You need pats ring/ECU and and chip from the keys to reuse in your key from another escort gti otherwise you will have to change all your lock.... fuck that carefully use a small flat screwdriver to remove the tap on the key the chip looks like a house plug fuse just swap them over job done then you will not need to replace your locks
Old Jun 16, 2013 | 07:14 PM
Rune's Avatar
Rune
Thanks for the suggestion doga-ot, but a mate of mine has changed the locks, ignition etc on a mk6 before says it was dead easy, didn't take long and he's offered to pop over and do the whole lot for me so I don't see much point in me poncin around trying to bastardize keys
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
gingerturbo
Aug 11, 2015 09:44 PM
