Time Attack: Snetterton
Old Jun 9, 2013 | 09:13 PM
Miller 3's Avatar
Miller 3
Default Time Attack: Snetterton
2 fords on the top spots today!
That is all :0)
Old Jun 9, 2013 | 09:24 PM
nevsrevs's Avatar
nevsrevs
Good lads
Old Jun 10, 2013 | 01:11 PM
Cool who was one of them Ronnie
Old Jun 10, 2013 | 01:17 PM
Miller 3's Avatar
Miller 3
Yes mate, fastest in qually and a win in the final :0)
Marc in the frs powerd S1 was the other :0)
Old Jun 10, 2013 | 02:31 PM
RigPig's Avatar
RigPig
Its was a good day, the escort lokked, and sounded really good.
Ronnies car was sounding amazing at the end of the start/ finish straight.
Old Jun 10, 2013 | 03:09 PM
gus's Avatar
gus
Well done Ron and crew
Heard you had bearing collapse again
(Set if mk's uprights next?)
Awesome result for mark again 3 for 3
Old Jun 10, 2013 | 04:52 PM
Miller 3's Avatar
Miller 3
We have only ever hads one come loose gus, the other two failiers looks like they just got too hot and siezed up! I think it may be down to the fact we run spacers,wide wheels and sticky tyres? Pluss Ron dose love a curb!!!
I think we need too look in to a better hmp grease maybe?
Old Jun 10, 2013 | 05:04 PM
Brian's Avatar
Brian
Congratulations to the Ford's
Brian
Old Jun 10, 2013 | 05:56 PM
gus's Avatar
gus
my bad
i knew you had bearing related problems
Old Jun 10, 2013 | 06:07 PM
Staffi's Avatar
Staffi
Well done fellas
Old Jun 10, 2013 | 07:33 PM
Top result.Its great to hear Ronnie is doing well.
Old Jun 10, 2013 | 08:30 PM
Miller 3's Avatar
Miller 3
Thats cool, I just wanted to explain what was happning bud as I wonder if anyone else has had this? Mk hubs would be nice, but there is no money in the pot
Old Jun 10, 2013 | 08:39 PM
fordrallycar's Avatar
fordrallycar
The amount you had to drink Saturday night i wounder how you do F**k all on a Sunday fella its was a good night fella tThank you for the beer fella it was good to catch up with you guys
Old Jun 10, 2013 | 08:49 PM
James @ M Developments.'s Avatar
What bearings does he use Doug? I would be using timkin, not happy shopper ones.
And get them pressed in rather than impacting
If that doesn't work then its simply a case we have pushed them past the limit of the std bearings so bigger and stronger is the only way forward,
I would advise short term sourcing a set of hubs and arms and have new bearings fitted in them so they can be swapped at events quickly should another failure occur, I'm sure they are pretty easy to get hold of for cheaps.
Which one was it? The O/S/F collapsed at round 1
Old Jun 10, 2013 | 09:48 PM
RONNIE AMIS's Avatar
RONNIE AMIS
This time it was the n/s/f. The lap before I took the kerb at murrays which is the left on to the pit straight and heard a clonk. Figured it was just a rise joint knock or something. Next lap round. Took the same amount of kerb and the wheel locked up resulting in the car having to be lifted back to the pits.
Would love a set of proper uprights. Just need the budget for them.
Kidney for sale anyone??
Old Jun 10, 2013 | 10:14 PM
Tony Ryan's Avatar
Tony Ryan
You just need proper Grease mate , Red Redline or Neo , and then keep a spare in the van .
I changed mine every other event after I knocked both out over a race weekend .
Old Jun 11, 2013 | 05:54 AM
Miller 3's Avatar
Miller 3
That is what I thought Tony as if you look at them it looks like the grease has burnt off and gone dry.. Deffo somthing we need to get on top of ay :0)
Old Jun 11, 2013 | 05:27 PM
If they are overheating surely that means they cannot take the load on them?
Have to measure the hub temps at the next round and see just how hot they get
Old Jun 11, 2013 | 06:02 PM
Tony Ryan's Avatar
Tony Ryan
Spot on , the std hubs are crap , JG did experiment with milling them out and using a bigger bearing ,I cant recall if theres a spindle from the Ford range that has a bigger bearing land on it but its possible . Look at the size of a std bearing and you'll see just how small they are .
Old Jun 11, 2013 | 08:11 PM
Ginge !'s Avatar
Ginge !
just finding my feet
What about transit bearings ?
Old Jun 12, 2013 | 05:37 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Ronnie breaking the gear stick
Old Jun 12, 2013 | 12:53 PM
johnyjn's Avatar
johnyjn
Top result guys
M K
Shows & Track Days
16
Nov 8, 2015 06:18 AM
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
