1300 ohv to 1600 xflow
soooo...... its a little bit backwards....I have a 1300 mk4 escort two door estate in white, Im looking at converting it to a 1600 xr2 engine from a mk1 fiesta which is about 90 horse power compared to my current 60... so this is the list for my plan.
XR2 1600 motor with a 5 speed box.
bike carbs.
4 branch manifold.
mid spec cam.
and possibly a big valved head and gas flowed.
the only things I don't know where to go with is drivshafts and what other bit and pieces I need to do the conversion... obviously I know ill be going from electronic ignition to the distributor... but id probs swap it over to electronic at some point....
I have chosen this option as it suits my insurance and also suits my work load...
any ideas and thanks in advance
Johnny
bike carbs.
4 branch manifold.
mid spec cam.
Johnny
getting your flywheel lightened? if your down at rebuilt stage get it all balanced , pressure plate too would shock how much that itself is out .
would a standard zetec not be cheaper to insure? easy to put in too! plus it would do 100k miles standing on its head and is 130bhp out of the box. just food for thought...
well the point is to keep it old school.....an xr2 engine bolts straight except one mount.....I don't want any electronics at all.....but I do want bike carbs they sound brilliant as well as the other positives to having them
I thought the crank, timing chain area is different from the Xr to the RWD crossflow and possibly the block and oil pickup/ sump. Yes, the heads the same as is the pistons and rods. Good luck with the swop.
chowfornow
14
Jan 5, 2019 09:01 PM
track.focus'd
Aug 12, 2015 05:53 PM
