Where to get sump welded?
Hi people,
I've got a 2.0 blacktop crankcase which i want drilled out and a few bosses welded to it (2 for breathing 1 for return).
Anyone know where i can get this done in the Essex area. I'm based in Rainham (a few miles from Lakeside shopping centre)
OR OR OR
Is there an alternative route to doing this.. heard about opening up the timing pin hole (which i don't want to do as i don't want any swarf in the currently spotless engine)or is there a way of fitting threaded fitting into the crankcase instead of welding.
Cheers to anyone can help, as soon as this is done i can assemble the bottom end
OR OR OR
