Fuel mixture
Old Jun 3, 2013 | 02:22 PM
kurdt5's Avatar
kurdt5
Default Fuel mixture
How do adjust the fuel on an efi engine?
I way to rich, need to even it a bit before I can book a tune up
Old Jun 3, 2013 | 06:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If the anti tamper seal is still intact on the FPR then don't touch it.
If it's been removed then you'll need a WBO2 to set it correctly, clockwise for more fuel, anti-clockwise for less.
Old Jun 3, 2013 | 09:12 PM
Red_bull's Avatar
Red_bull
How come you think you are low on fuel pressure?
Old Jun 3, 2013 | 09:25 PM
kurdt5's Avatar
kurdt5
My spark plugs were soaked with petrol
Old Jun 3, 2013 | 09:49 PM
Rob_DOHC's Avatar
Rob_DOHC
What injectors are fitted? Is it the standard ECU?
If its using standard injectors, and its a standard ECU you may have a faulty coolant temperature sensor.
Old Jun 3, 2013 | 10:13 PM
kurdt5's Avatar
kurdt5
All standard, I'll check the sensor thanks bud
Old Jun 3, 2013 | 10:26 PM
Rob_DOHC's Avatar
Rob_DOHC
No worries. If everything is standard and the fuel pressure regulator hasn't been tampered with you probably have a duff sensor or wiring. If the ECU thinks it -20 deg C outside you will be very rich indeed.
Good luck
Rob,
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
