Should I be concerned about this? See photo..
Basically for some reason (well it's not really a mystery) the plastic injector seat on the manifold has broken up much like the shit thermostat housings do. Anyway, will this cause me issues with boost leaks because it is still well sealed around the sides of the o-rings.
Really don't want to buy another manifold!
Really hoped the manifold would be a saving on the project. balls!
I read somewhere that these are generally a bit leaky, what's a good alternative?
i honestly would prefer to use the same type of manfold to make the whole thing easier but i can't chance buying one off ebay in-case it's the same...
I'm gonna buy a new one then
What did you do about the big breather hole on the back of the inlet, it used to go to the block but that's been blanked, and even if it wasn't. That would send boost into the block wouldn't it? Making the breathers and turbo useless??
Bailes1992
Sep 19, 2015 02:17 PM
Sheepdisease
Aug 30, 2015 09:11 PM
