Aux belt size
Hi,
does anyone know what aux belt number / length I need for a late 4x4 Cossie with the power steering deleted? It is the multi ribbed belt not the twin V belt system.
I will be going Corsa C and so no need for hydraulic PS anymore.
Scrap that - will have to use the twin V belt system with shorter belts as the tensioner on the multi ribbed jobbie won't work - doh!
Anyone know the belt size for the twin set up without PS?
Measure it then use the online gates catalogue for the part numbers they're only around £4 each.
I bought a set from MSD and they were too short for my 4wd so I went for 9.5x 925mm
I will when I can get to it - just wondered if anyone knew.
Thats excellent, thanks
