sandwhich plate of ebay keeps leaking
Old Jun 2, 2013 | 07:26 PM
Red_bull's Avatar
Red_bull
Default sandwhich plate of ebay keeps leaking
Guys,
My oil sandwhich plate keeps on leaking. I used the supplied conical bolts to block two ends.
The conical bolts should be enough isn't it? No washers or anything?
As it's alu i think the bolts are quite tight already?
Anybody had the same? How to solve?
Old Jun 2, 2013 | 07:58 PM
studabear's Avatar
studabear
is it a tapered thread?
Old Jun 2, 2013 | 08:39 PM
oibren85's Avatar
oibren85
If in Doubt Flat Out...
Would PTFE Tape sort that or would the oil destroy it?
Old Jun 3, 2013 | 08:37 AM
Red_bull's Avatar
Red_bull
Yes, this is what i tried to say with "conical bolts"
Sorry i'm dutch!
Old Jun 3, 2013 | 09:22 AM
lacey's Avatar
lacey
Ptfe tape will sort it and it will last in till you remove the bolt
Old Jun 3, 2013 | 10:54 AM
Red_bull's Avatar
Red_bull
That will be my next try then!
Old Jun 3, 2013 | 04:53 PM
xrmalin's Avatar
xrmalin
Mine kept leaking like that too & it took me a while to sort it properly as it kept running down the plate making me think it was the o ring seal on to the block so after taking that on & off a few times I spotted where it was actually coming from & some ptfe tape on the bolts sorted it out.
Old Jun 3, 2013 | 08:36 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
I used ptfe tape on all mine when I fitted it and never had so much as a drip from any of them
Old Jun 3, 2013 | 08:49 PM
Red_bull's Avatar
Red_bull
Thanks good to know!
I assumed that the tapered thread should be able to close it down completly isn't this?
I mean it's BSP which should mean gas tight aswell isn't it
RB26DETT
Feb 5, 2022 01:54 PM
Rsmat
63
Sep 25, 2015 12:11 PM
nikki.n.tom
Sep 15, 2015 08:20 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Sep 3, 2015 10:49 AM
