L8 ecu chips
Old Jun 2, 2013 | 09:40 AM
Karl 3dr's Avatar
Karl 3dr
Default L8 ecu chips
Just wondering if someone could answer a question I've had about my L8 ecu I have for sale please?
Are all L8 chips interchangeable? As in, will a chip from a red L8 fit and work ok in a green L8?
Thanks in advance, Karl
Old Jun 2, 2013 | 10:21 AM
KSA-Cossie's Avatar
KSA-Cossie
Yes they do Karl
Old Jun 2, 2013 | 10:44 AM
Karl 3dr's Avatar
Karl 3dr
Ok, thanks Kev
Old Jun 2, 2013 | 04:01 PM
RSCossieGaz's Avatar
RSCossieGaz
Sorry to jump on ur thread karl but whats the differences between red L8 and green L8 as i be on hunt for one real soon?
Old Jun 2, 2013 | 04:24 PM
cosworthkev's Avatar
cosworthkev
Red is pre cat green is post cat.
Old Jun 2, 2013 | 05:29 PM
Karl 3dr's Avatar
Karl 3dr
No problem mate, what that guy said lol
Karl
Old Jun 2, 2013 | 06:37 PM
boost mad's Avatar
boost mad
Yep, Just as above. Apparently, the only differences are in the software, so as soon as you remove the chip, there is no difference.
Old Jun 2, 2013 | 06:40 PM
Jay,'s Avatar
Jay,
Sponsor
But there are different boards IE pectel or weber and i think the protocols are very different
Old Jun 2, 2013 | 06:58 PM
martysmartie's Avatar
martysmartie
Pectel encrypted there software, hence you need a pectel board to run it.
As said the only difference between the two is the software, obviously in the red top case it was not calibrated for CL.
Martin
Old Jun 2, 2013 | 07:36 PM
jamie's's Avatar
jamie's
what he says,
a chip written for a pectel board wont work in a weber board and vice versa
so if you've already got a chip then you need to get he board to suit that,
or if your ordering a chip you need to know what type of board you have
however the boards are interchangeable and can be quickly swapped over on the same l8 ecu
Old Jun 3, 2013 | 12:22 PM
martysmartie
Originally Posted by jamie's
what he says,
It shouldn't make any difference in this case...
If someone buys it who has a Pectel chip, they would have a 'Pectel board' as well, so they can simply transplant them into the new ECU, if they don't then they can just fit the chip.
Martin
Old Jun 3, 2013 | 12:41 PM
Jay,'s Avatar
Jay,
Sponsor
Martin
Don't alwayse work that way mate you end up with the fuel pump continuously running or no spark or just nothing at all ! Had these issues with my mates escort cossie a couple of years ago
Old Jun 3, 2013 | 08:57 PM
martysmartie
The chips can be swapped amongst ECU's of the same type, issues such as you describe sound like you are trying to run a Pectel chip without the board to decrypt it, thats merely all the pectel board is, a hardware key.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
RSmark84
Sep 13, 2015 01:29 PM
