Wasted spark L8 ECU - SOLD
As above, I bought this for my car but my plans have now changed so have decided to sell it on,
L8 with wasted spark board, good working order £265 plus postage, or collection is fine.
Cheers, Karl
Cheers, Karl
Have you got the other bits needed to make a full wasted spark set up or are they not that much to buy?
Also does the ecu have any form of aftermarket chip in it?
Reason I ask is my car is on the old type of dizzy system and the whole kit is say £400 from msd so not sure if I'm better off getting the whole kit and caboodle off them or does this do everything I need?
Thanks,Vaughan.
Thanks,Vaughan.
Thanks,Vaughan.
Thanks,Vaughan.
You will need a set of leads 2nd ignition amp sub loom and coil pack
If karl hasn't got the bits I've got a coil pack kicking about somewhere but its just a ford one also have a set of original leads I modded to go on coil pack if you were interested for a bargain price!!! then all you would need is the sub loom and 2nd ignition amp and away you go!!
Thanks,Vaughan.
Thanks,Vaughan.
I have got all the other bits to make up the kit, leads, coilpack, 2 ignition amplifiers and mounting bracket, loom etc, I was going to use them when I put my other engine in as I've already got another ecu which I'll put a wasted spark board in, but I'm open to an offer if you wanted the lot mate?
It's all in very very good condition
Karl
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
