s1 rs non starter
Old Jun 1, 2013 | 07:12 PM
knighty139's Avatar
knighty139
Default s1 rs non starter
hi all im new to this forum so if ive posted in the wrong place i apologise
i have a s1 rs turbo im curently rebuilding, since fitting the engine back in i cant get it to start
ive nailed it down to fuel but thats it
the fuel is pumping through the filter to the metering unit but going no further,is there a way to bleed these
i have spark, compression and loads of fuel just not getting to the injectors
any help is appreciated
ian
Old Jun 1, 2013 | 07:54 PM
mercury grey minter's Avatar
mercury grey minter
Had a similar problem when I rebuilt mine.Try taking off the air filter housing so you can see the flap on the fuel metering unit.Get someone to turn the engine over while you gently press down on the flap.
Old Jun 1, 2013 | 08:02 PM
knighty139's Avatar
knighty139
hi thanks for reply
i have tried this but feels like there is no resistance in the flap i changed metering unit today but still the same,
i have no dash lights would this add to my problem although i have ignition ect
Old Jun 1, 2013 | 09:13 PM
whizzisat114's Avatar
whizzisat114
I remember some one having trouble with s1 before and they'd got ecu and engine ecu plugs wrong way round.
Old Jun 2, 2013 | 06:25 AM
knighty139's Avatar
knighty139
the car has run with the wiring as it is but just not very well as not getting fuel to every injector
now not getting fuel to any of them apart from the one underneath the inlet manifold
trys to start then nothing
with the pipes loose on metering unit and on injectors theres nothing
but if you undo the pipe feeding the unit and feeding the 5th injector the fuel pi$$es everywhere
CONFUSED!!!!!!!!
Old Jun 2, 2013 | 09:21 PM
mercury grey minter
Got mine to run for a bit but then died,wouldn't start again.Took it to a tuner (JAMSPORT)and he got it running and starting first time every time.Adjusted the metering unit and set it up properly.My advice would be take it too an expert as the metering units on these can drive you crazy.
Old Jun 2, 2013 | 09:24 PM
knighty139's Avatar
knighty139
hi yes I read that thread today and see Jamsport had sorted it I got his number will calm him tomorrow. Thanks
Old Jun 3, 2013 | 04:50 PM
fatty's Avatar
fatty
Hello,
just thought id drop in a quick note too say i had exactly the same problem with my S1 after a rebuild and it drove me nuts !
In the end it fired up for me ..from memory i spent alot of time loosing banjos ( to try and bleed out any air ) and getting a mate to press the flap down etc. Don't give up ..although it is annoying.
Few things to consider that MAY help..
- Make sure all the vacuum pipes are on and tight..i've learnt that the MFI system HATES leaks
- Take the plugs out and spin it over just in case the engine is flooded
Good news is once it starts it should be fine ive left mine for a while now so im hoping itll be ok lol
let me us know how you get on ?
Good luck , pete
Old Jun 3, 2013 | 05:22 PM
knighty139's Avatar
knighty139
Nuts is not the word
If this car was insured I would of burnt it by now.
Spoke to Jamie at Jamsport today he gave me a few pointers I will try all suggested tips when I next have a play
Failing that it will be a trip to Jamie himself as I am now bald
Old Jun 4, 2013 | 08:14 PM
fatty's Avatar
fatty
cool ,.. what pointers did he give you you dont mind me asking ?
just for future reference.
Old Jun 4, 2013 | 08:19 PM
matts1's Avatar
matts1
can't offer advise but may also be worth popping on to www.seriesoneturbo.co.uk as there are endless people that have stripped and built S1's on there and will have encounted every issue under the sun.
Plus it is a must website for every S1 / mk3 escort owner and a good community, was a godsend when I had mine.
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
