wastegate not very loud since anti surge turbo fitted??
Old Jun 1, 2013 | 08:31 AM
lockie's Avatar
lockie
Default wastegate not very loud since anti surge turbo fitted??
not to sure on what the anti surge compressor housing actually do???
my t38 gave a massive/loud waste gate sound before but since i've brought a new t38 with a anti surge housing its no where near as loud???
prob a stupid question but if u don't know then find out!
Old Jun 1, 2013 | 09:08 AM
pee vee's Avatar
pee vee
Do you mean it's not chattering as much? (nothin to do with waste gate BTW lol)
Or do you mean that the noise on boost isn't as loud anymore?
Old Jun 1, 2013 | 09:17 AM
lockie's Avatar
lockie
well both tbh, I used to get a huge air induction noise on boost then a loud chatter on lift off.
now I get a supercharger whine for a few seconds low down & a quieter chatter
Old Jun 1, 2013 | 09:21 AM
pee vee's Avatar
pee vee
Well, it has got a different front end on the turbo mate.. And that's the bit that makes the chattery noise. So probably will sound different.
Old Jun 1, 2013 | 05:54 PM
scholes's Avatar
scholes
It says on turbo technics website that the run quieter
Old Jun 2, 2013 | 09:28 AM
stevieturbo's Avatar
stevieturbo
C**t
And that chatter is air backing up because you dont have sufficient dump valve. It may sound good, but isnt always healthy for the turbocharger ( although may also do no harm to some )
A ported shroud will always run quieter in this respect, as it has more air passages for the air to escape back out under such circumstances.
Old Jun 3, 2013 | 09:37 AM
xr-stu's Avatar
xr-stu
That chatter noise is from air backing up in the inlet and being forced back through the compressor, which is exactly the same as surge. Except surge happens with the throttle open. Hence why you're not getting the same noise with an anti surge compressor housing.
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
Aug 14, 2015 07:29 AM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
Hellraiser
Aug 8, 2015 04:19 PM
