Oil breather... Help
Just had an oil breather fitted to my series1, now the temp gauge has got a mind of its own, temp goes off the scale then back down again.
What is the reason for this ???
right sorry for the late reply been out watching the playoff final, but ive checked all th wires and they seem to be in contact. dnt want to sound out of place but where would i b looking for the sender???
The wire has a push on connector with a rubber cover over it just pull it off and follow the wire to see if theres any brakes along the line ,also check the connector itself just incase its gunked up with crap if that doesnt work try fitting a new sensor.
deathrider666
Sep 28, 2015 06:12 PM
