Making my own Cosworth loom
Old May 26, 2013 | 07:15 AM
Cossy Mike's Avatar
Cossy Mike
Default Making my own Cosworth loom
Hello,
As some of you will know I've been rebuilding my Sapphire 4wd Cosworth, it's now about 80% complete.
I have just started to tidy up the wiring on the loom and would really like to get new one. There nothing wrong with the one that's fitted now and appears to be in good condition, however, it is as old as the car and as I've replaced everything for new I might as well do this.
I've been having a good look around on different pages on here and around the net and making the loom itself seems a straight forward job.
I bought the fuel pump, coil requiring loom already but I'd like to hard wire it in.
Can people put any hints or tips on here that could help me or anyone else along the way?
I've got the diagrams off biggturbo etc to start with.
Ideally I would like original coil wiring to use until I go wasted spark so I'm going to hard wire the twin amp loom in and fuel pump relays.
What do I do with the 2 diagnostic plugs nearest the 35 pin ecu? Do I repin them or loose them?
It also looks like I can loose a good length of cabling by cutting out the 3x8 way plugs off the bulkhead and hard wiring them in.
Thanks
It'll be a slow thread but ill update my progress as and when
Old May 29, 2013 | 10:25 PM
Thanasis's Avatar
Thanasis
Originally Posted by saphcosmike
Hello,
Thanks
What type of wire are you used for the map sensor line? thank you
Old May 30, 2013 | 07:55 AM
Cossy Mike's Avatar
Cossy Mike
I wasn't going to after reading older threads but I'm going for 3core screened cable on the map and 2core screened on the knock sensor as per original wiring
Old May 30, 2013 | 08:01 AM
Cossy Mike's Avatar
Cossy Mike
I would like to know what to do with the fuel pump relay as looking at aftermarket looms they are not part of the loom.
I have a fuel pump rewiring loom I bought a while back and was planning on using that.
Old May 30, 2013 | 09:48 AM
Thanasis's Avatar
Thanasis
where did you find this type of wire please?thank you very much
Old May 30, 2013 | 11:02 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Make your sensor wires into twisted pairs as far as possible (or twisted triples) as it eliminates a lot of the interferance.
Tony at turbosystems knows alot about how they developed the motorsport looms to deal with interference and they went the twisted pair route he said IIRC.
Old May 30, 2013 | 01:51 PM
Cossy Mike's Avatar
Cossy Mike
Twisted pairs - It'll be easier to trace them back as well ,good tip thanks
I've picked up on one of your post off a while back when you made the Yellow braided loom. Helped me a lot so far, thanks
I've noticed you've still got the Fuel relay still part of the main loom. I was going to try and rewire it direct but looks a right ball ache and not really achieving much so I don't think I'll bother.
I'm still waiting on a few bits in the post them I can get cracking
Old May 30, 2013 | 01:54 PM
Cossy Mike's Avatar
Cossy Mike
I used these for most of the stuff, P&P a bit expensive though
http://www.polevolt.co.uk/acatalog/Screened_Cables.html
Old May 30, 2013 | 05:57 PM
Thanasis's Avatar
Thanasis
Thank you very much pal!!
Old May 31, 2013 | 04:35 PM
Cossy Mike's Avatar
Cossy Mike
Just a quick question to anyone,
Can I leave the air canister plug off the loom? It looks like it will never be used
Old May 31, 2013 | 06:29 PM
Psycho Warren
Carbon Crazy
Whats one of them
Old May 31, 2013 | 08:16 PM
Cossy Mike's Avatar
Cossy Mike
Whats one of them
Pin 7 on the ECU? Did you just leave yours off ??
Thanks
Waiting for the grommet and jpt connectors and I can get started
Old Jun 6, 2013 | 12:28 PM
Cossy Mike's Avatar
Cossy Mike
Another little tester......
I don't want to be using an old suppressor off the loom as I'm making new....
I understand it's a simple capacitor, BUT what value is it?
1uF 250v or 500v?
Old Apr 3, 2014 | 01:27 PM
opposite lock's Avatar
opposite lock
Did you ever get to do your loom Mike?
Old Apr 3, 2014 | 02:29 PM
fezzajsy's Avatar
fezzajsy
I think he did mate check his thread..
Old Apr 3, 2014 | 06:19 PM
opposite lock
going there now
Old Apr 5, 2014 | 04:09 PM
Cossy Mike's Avatar
Cossy Mike
Originally Posted by opposite lock
going there now
Yer all done and tested as far as I can before running it, turned out really well
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
jdsjojo
Aug 1, 2015 08:50 PM
