Has anyone ever had a shell sandblasted??
Old Mar 16, 2005 | 06:12 PM
Rippers's Avatar
Rippers
Monte Geek
Default Has anyone ever had a shell sandblasted??
I need a lot of bodywork on my Series 1 shell and i've just had a quote from a body shop today, he suggested for the best finish having the panels removed/cut back and having the whole shell sand blasted! so all the rust/old filler and dodgy parts are fully exposed and can all be repaired properly. This sounds all good but where would I get someone to sandblast a shell! as he didn't know anyone!
Any advise? comments?
Old Mar 16, 2005 | 06:19 PM
GARETH T's Avatar
GARETH T
my friends can do this for you,,,,
when i went down there, they was blating back a etype shagwaar
Old Mar 16, 2005 | 06:20 PM
NUTS RuS's Avatar
NUTS RuS
Had all my insides and engine bay done and all of the srtonger points on the outside.
The heat generated by the sand will either rip through or seriously warp a thin panel such as a wing etc. Be careful.
I got mine done locally for Ł40 (thats the whole car). I know of two places up here that will do it and of them is a general balsters and the other is a restorer of old tanks (army type) both pretty good at there job.
But be warned it gets everywhere - inside all the box sections etc. I had my car fully stripped so that there was not a single nut/bolt bit of glass or piece of wire on it anywhere.
Old Mar 16, 2005 | 06:30 PM
GARETH T's Avatar
GARETH T
thats dammmmm cheap
Old Mar 16, 2005 | 06:31 PM
Rippers's Avatar
Rippers
Monte Geek
I'm changing so many panels I quess it would make sense to sandblast the shell then. Blimey this shell will be mint! and we not talking crazy money either I've go for it I think.
I can imagine the sand gets everywhere! spend a few days knocking the box sections with the hoover in hand!
Rippers's Avatar
Rippers
Monte Geek
thats dammmmm cheap
Yeah I better get prepared to double/triple that Ł40 down south lol!
Old Mar 16, 2005 | 06:58 PM
NUTS RuS's Avatar
NUTS RuS
I thought Ł40 was dear as it was mates rates Came back looking like new tho and allowed me to get on with the seam welding without getting smoky burning paint marks everywhere
Under bonnet / battery tray area
Fuse box area
Inside rear
I had the car on a revolving stand whilst doing the other work and sand was coming out of it for weeks afterwards but it was WELL worth it
Old Mar 16, 2005 | 07:04 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
i do sand blasting
Old Mar 16, 2005 | 07:05 PM
GARETH T's Avatar
GARETH T
thats dammmmm cheap
triple,,,, your joking right
you seen the price on grit
NUTS RuS looks the bollox mate
Old Mar 16, 2005 | 07:09 PM
Rippers's Avatar
Rippers
Monte Geek
Originally Posted by Freddy_mercury_magic
i do sand blasting
Fancy doing my shell then??
Old Mar 16, 2005 | 07:11 PM
Charlie Chalk
Unknown.
if you can get it to oxford might
Old Mar 16, 2005 | 07:17 PM
Rippers's Avatar
Rippers
Monte Geek
May hold you to it! got a lot more stripping to do first!
Old Mar 16, 2005 | 07:22 PM
NUTS RuS's Avatar
NUTS RuS
Was worth it to me as the next stage of the build was all the seam welding. It made it all so much easier
Would I do it on a road car tho...... erm NO. Toooo much hassle.
Old Mar 16, 2005 | 08:25 PM
Iain Mac's Avatar
Iain Mac
I got my XR4i shell blasted by a commercial vehicle bodybuilders for Ł200. That was inside and out and fresh primer-coat afterwards.
The grit gets everywhere and I don't think I'll ever get it all out despite using a hoover to suck, and the compressor to blow.
Old Mar 16, 2005 | 08:28 PM
M Brian's Avatar
M Brian
that looks like porn!!! spot on!
Old Mar 17, 2005 | 06:55 AM
Markb_s1's Avatar
Markb_s1
Ł40 IS DIRT CHEAP.. I WAS GONNA HAVE MY MK2 DONE.. WAS LOOKING AT UPWARDS OF Ł500 (oops - exceuse caps!) to get mine done.
Apparently you have to be very careful when doing it because the heat from the sand/beads can distort panels, especially large ones like the roof.
Central Blast Cleaning do it, and i also spoke to another specialist company to do it who were more expensive. Both of them had done plenty of car shells and knew exactly when they were doing.
I chose against it due to the cost, but really wish i had now, after spending days under the car with a scraper and angle grinder to remove all the underseal and ziebart.
Old Mar 17, 2005 | 07:07 AM
saff_cossie's Avatar
saff_cossie
all the ones I have found at the beach have been like that
Old Mar 17, 2005 | 07:40 AM
Central blast cleaning will also do this 01295 278233
Old Mar 17, 2005 | 07:48 AM
NUTS RuS's Avatar
NUTS RuS
It wont remove underseal tho It just bounces off that.
I still had to do all that by hand to remove it, just to save a bit more weight
Old Mar 17, 2005 | 09:31 AM
Markb_s1's Avatar
Markb_s1
interesting.. when i spoke to central blast cleaning and the other people whose name i forgot they said that they could remove underseal with it no problem... that was one of hte main reasons i was going to have it done!
Old Mar 17, 2005 | 09:49 AM
JRST's Avatar
JRST
Central Blast are really expensive. Alot more than Ł40.
Old Mar 17, 2005 | 10:42 AM
Rippers's Avatar
Rippers
Monte Geek
try Ł460 + vat
Old Mar 17, 2005 | 10:46 AM
Markb_s1's Avatar
Markb_s1
i did say upwards of 500!
Old Mar 17, 2005 | 10:49 AM
NUTS RuS's Avatar
NUTS RuS
Looks like I dropped on a good price then The white stuff around the heater intake area in the 2nd pic above is the original Ford sealant, the beads just bounce off it, cleaned it up though and it removed all the original paint
Old Mar 17, 2005 | 11:30 AM
JRST's Avatar
JRST
paul yeah... but remember once all that has been blasted you have to pay them for repair the lot, where the filler was and everything.
Trust me, I can see you paying alot more.
Think about it
Old Mar 17, 2005 | 12:55 PM
I bought a series 1 turbo shell that had been done and sprayed with etch primer. Makes a cracking job. As said above though, need to be careful with the roof/quarters and wings etc - they can be dented quite easily
And the bloody sand/grit gets everywhere...!!!
Old Mar 17, 2005 | 01:02 PM
Rippers's Avatar
Rippers
Monte Geek
I spoke to a few companies today, most where putting me off doing it! I'm not sure if the shell would benefit enough to justify the cost. Plus the hassle would be mental transporting a bare shell to and from a blast shop. I'll have another think about it.
Old Mar 17, 2005 | 01:09 PM
Rossco's Avatar
Rossco
Make sure they know what they are doing, as some one said above you can easyly bend thin panels, the guy we used to use where i worked was proper carefull, he did a fibreglass Lotus shell, real nice job, he is based just outside of Colchester i think, bit far for you though.
Old Mar 17, 2005 | 01:11 PM
Markb_s1's Avatar
Markb_s1
one of the main things to bear in mind is that as well as removing the rust, it does necessitate repairing a lot of things that would otherwise have gone unnoticed for years, or maybe forever!!
Old Mar 17, 2005 | 02:44 PM
NUTS RuS's Avatar
NUTS RuS
Rust...... ? I only had mine done to remove the original paint as there was no rust If a panel has bad rust on it it will blow straight through, then your into a full replacement job anyway. Sort of defeats the object ??
bobsworth
77
Mar 24, 2016 09:30 PM
gambo08
Feb 4, 2016 10:49 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
