Which wide band to use with ms??
Old May 22, 2013 | 11:19 AM
R-A-J's Avatar
R-A-J
Default Which wide band to use with ms??
As above,
what is the best wide band sensor/system to use with megasquirt? Its for my st170 mk1 fiesta n/a
Old May 22, 2013 | 11:26 AM
rsmark86's Avatar
rsmark86
With ofam I got told to use a AEM wideband?
Old May 22, 2013 | 11:28 AM
R-A-J's Avatar
R-A-J
Ideally I would also like to have a visual guage but not sure if this will need an additional sensor, mosule unit etc, been looking at aem and inovate and they seen around the same price
Old May 22, 2013 | 12:19 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
I run an innovate lm2 kit mate works spot on
Old May 22, 2013 | 12:24 PM
luke19790_3's Avatar
luke19790_3
i have aem wideband + gauge which also gives feedback to my MS2.
Old May 22, 2013 | 05:29 PM
studabear's Avatar
studabear
aem is what i use with m/s
Old May 22, 2013 | 10:11 PM
R-A-J's Avatar
R-A-J
chaos what do you think of this? will it do both the guage and the ecu?
http://www.ebay.co.uk/itm/AEM-30-410...item3f1a69db86
Old May 23, 2013 | 06:58 AM
Ade500's Avatar
Ade500
Fixing Fords
Yep, they feed the gauge and give you an ecu output. I used the non digital faced one as it was more in keeping for my dash and personally I found it easier to read.
Old May 23, 2013 | 07:03 AM
luke19790_3
That's one I use
Old May 23, 2013 | 08:58 AM
R-A-J's Avatar
R-A-J
ade which one? I to would also like to keep the appearance retro and authentic so to speak
Old May 23, 2013 | 09:01 AM
JonnyBravo's Avatar
JonnyBravo
Use the Aem uego Raj, very accurate and reliable.
There is a 5 volt output which you wire to the ms lambda input
Old May 23, 2013 | 09:13 AM
R-A-J's Avatar
R-A-J
you going classic for mr bravo? i will hav some presents for you
Old May 23, 2013 | 09:18 AM
JonnyBravo's Avatar
JonnyBravo
Yes mate I reckon I will be there.
Old May 23, 2013 | 09:22 AM
R-A-J's Avatar
R-A-J
sound, will drop you a line DEFO tonight about 7 ish whilst im scoffing some pizza at work.
can you confirm that the link i posted is all I need though before i buy it?
Old May 23, 2013 | 09:28 AM
JonnyBravo's Avatar
JonnyBravo
Sounds good mate and yes that's the exact one we use on most cars. Good price from them too!
Old May 23, 2013 | 12:15 PM
Ade500's Avatar
Ade500
Fixing Fords
I will get a pic tonight and the instructions for you mate. I used the black face ( for a sierra) and the backlight choice of colours are great, and I wired it so it dims with the dash adjuster to.
Old May 23, 2013 | 07:02 PM
Ade500's Avatar
Ade500
Fixing Fords
Here you go the part no is on the first page
Bit dark in the garage
Old May 23, 2013 | 08:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
well, i've used two with the ms, vems cost about £300 with egt probe, the second was an MTX from innovate.
the MTX was about £150, i only used it for a short time but was pretty good, compact and piss easy to fit.
setting up for wideband output to megasquirt was simples too.
the Vems i had been using for years without any issues, only got the mtx when i had an electrical gremlin after alternator failed and caused mis readings, was just a shitty earth in the end
Cosnada
Jan 7, 2016 05:30 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
benw456
Sep 16, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
